OS-SL-T: 1070 Linear Static Analysis of a Plate with a Hole
In this tutorial, a plate with a hole is analysed.
- Import the model into SimLab
- Define and solve the model setup
- View the results
Launch SimLab
Import the Model
Define the Solution
Define Constraints
Apply Forces
Apply Material and Apply Properties
Solve and View Results
Solve the Solution
Interpret the Results
![](../../../images/solvers/simlab_linear_static_analysis_example_displacement_results.png)
Figure 8. Example Displacement Results (Resultant)
![](../../../images/solvers/simlab_linear_static_analysis_example_stress_results.png)
Figure 9. Example Stress Results (VonMises)
