OS-HWX-T: 6040 Spot Weld Fatigue (FPM) using S-N Method
Before you begin, copy the file(s) used in this tutorial to your working directory.
Spot weld fatigue can only be applied to spot welds between two shells. The spot weld location is defined by three attributes, sheet 1, sheet 2, and the nugget. The sheets are defined by shell elements, and the nugget is defined by CWELD, CBAR, CBEAM, or CHEXA elements. The nugget can be directly connected to the shells or RBE2/RBE3 elements can be used to connect the nugget to the shells.
A frame is experiencing frontal and rear torsional loads in addition to vertical bending. Welds are modeled between the sections forming the frame.
Figure 1. Spot Welds Modeled between Two Frame Sections
You will be able to calculate the damage that occurs at the spot weld locations. The solver deck setup is done using process manager. In brief, the following contents are covered:
  • Launch Fatigue Process Manager
  • Import a model
  • Create fatigue subcase
  • Define fatigue analysis parameters
  • Define fatigue elements and S-N properties
  • Define load-time history and loading sequence
  • Submit the job
  • View results summary and launch HyperView for post-processing
Launch HyperWorks/HyperMesh and Process Manager
The model being used for this exercise is that of an automotive frame. The fem file consists of the 3 static load steps to which the frame is subjected to – Frontal torsion, Rear torsion and the Vertical Bending.
  1. Launch HyperWorks (HWX) from the launch menu.
    A Launch dialog is displayed.
  2. Select the HyperMesh radio button and set Profile to OptiStruct and click the Create Session button.
  3. From the Templates ribbon, select the Analyze menu and select Fatigue PM.
  4. For New Session Name, enter <my_session_name>.
  5. For Working Folder, select your working folder.
  6. Click Create.
    This creates a new file to save the instance of the currently loaded fatigue process template.
    Figure 2. After launch Fatigue Process Manager (FPM)
    Figure 3. Fatigue Setup - Spot Welds
Import the Model
  1. Make sure the task Import File is selected in the Fatigue Analysis tree.
  2. For the Model file type, select OptiStruct.
  3. Click the Open model file icon files_panel.
    A Select File browser window opens.
  4. Select the Spotweld_CbarNugget.fem file you saved to your working directory and click Open.
  5. Click Import.
    This loads the control arm model. It includes a whole definition of two static subcases, elements sets, and material static properties, etc.
  6. Click Apply.
    This guides you to the next task Fatigue Subcase of the Fatigue Analysis tree.
    Figure 4. Import a Finite Element Model file
Set Up the Model
Create a Fatigue Subcase
  1. Make sure the task Fatigue Subcase is selected in the Fatigue Analysis tree.
  2. In the Create new fatigue subcase field, enter Fatigue-SpotWeld-Analysis.
  3. Click Create.
  4. For the Select existing fatigue subcase field, select the newly created fatigue subcase Fatigue-SpotWeld-Analysis.
    Fatigue-SpotWeld-Analysis is selected as the active fatigue subcase. Definitions in the following processes (analysis parameters, fatigue elements and properties, loading sequences, etc.) will be for this subcase.
  5. Optionally, you can choose to create all fatigue solver cards (such as FATPARM, FATDEF, FATEVNT, PFAT etc. that are created in subsequent steps) in a separate include file. For this, you should select the check box Create include file for fatigue solver cards (optional).
  6. Click Apply.
    This saves the current definitions and guides you to the next task Analysis Parameters of the Fatigue Analysis tree.
    Figure 5. Create and Select Active Fatigue Subcase to Process
Apply Fatigue Analysis Parameters
  1. Make sure the task Analysis Parameters is selected in the Fatigue Analysis tree.
  2. Select the following options:
    Analysis type
    S-N
    Stress combination method
    Signed von Mises
    FEA model unit
    MPA
    Mean stress correction
    GERBER
    Rainflow type
    LOAD
  3. Enter the following values:
    Certainty of survival
    0.5
    Gate
    0.0
  4. Check the box for Spot Weld Options. Select the follow options from the dialog.
    METHOD
    RUPP
    Mean Stress Correction
    FKM
    0.5
    THCKCORR
    YES
    NANGLE
    20
  5. Click Apply.
    This saves the current definitions and guides you to the next task Elements and Materials of the Fatigue Analysis tree. For details, consult the Altair Simulation 2022.1 help.
    Figure 6. Fatigue Analysis Parameters Definition
Add Fatigue Elements and Materials
Make sure the task Elements and Materials is selected in the Fatigue Analysis tree.
  1. Click Add Material.
    A Material Data window opens.
  2. For Material name, select Steel.
  3. Make sure Stress unit is set to MPA.
  4. For Ultimate tensile strength (UTS), enter 1000.
  5. Activate Spot Weld Material Properties, then click Spot Weld Material Properties.
    Figure 7. Material Data Definition
  6. Enter the values for Mean Stress Sensitivity, MSS2, Structural SN Curve along with bending and membrane SN curve material values.
    Figure 8. Spot Weld Material Properties dialog
  7. Click OK.
  8. Click Save.
  9. Click Add Property.
    Figure 9. Property Data dialog
  10. For Property Type, select Property - PBARL.
  11. For Property Name, select PBARL_4.
  12. Click Close to save the definition of the SN data for the selected property.
Define PFATSPW Property
This saves the current definitions and guides you to the next task Load-Time History of the Fatigue Analysis tree.
  1. Click Create button next to PFATSMW.
    A PFATSMW Entity Editor dialog opens.
  2. For Name, enter PFATSPW.
  3. For Card Image, select PFATSPW.
  4. Set SPTFAIL to All.
  5. Set ALPHA to 3.5.
  6. Set TREF to 1.0.
  7. Set TREF_N to 0.2.
    Figure 10. PFATSPW Dialog
  8. Set SF to 1.0.
  9. Click Close.
Update FATDEF Load Collector
  1. Click on Update button next to FATDEF.
    A FATDEF Entity Editor opens.
  2. Make sure the PTYPE and PBARL options are checked.
  3. Make sure the PID field under PBARL is pointing to PBARL_4 and PFATSPWID is pointing to PFATSPW card.
    Figure 11.
  4. Click Close to close the FATDEF dialog.
  5. Click Close button to close the Property Data dialog.
Apply Load-Time History
  1. Make sure the task Load-Time History is selected in the Fatigue Analysis tree.
  2. Click Add by File.
    A Load Time History window opens.
  3. For Load-time history name, enter LTH1.
  4. For Load-time history type, select CSV.
  5. Click the Open load-time file icon files_panel.
    An Open file browser window opens.
  6. Browse for load1.csv.
  7. Click Open > Import.
  8. Click Save to write the new load-time history into HyperMesh database.
    Figure 12. Import Load-Time History
  9. Click Plot L-T to show the load-time history.
  10. Close the Load Time History window.
  11. Click Apply.
    This saves the current definitions and guides you to the next task Loading Sequences of the Fatigue Analysis tree.
    Figure 13. Load-Time History Definition
Load Sequences
In this step, one event consisting of two load time history is created; in other words, the linear superposition of the stress caused by the two load time history is requested during analysis. Using this event, one load sequence is constructed.
  1. Make sure the task Loading Sequences is selected in the Fatigue Analysis tree.
  2. Click Add.
    A Load Mapping window opens.
  3. For Channels, select LTH1.
  4. Activate the radio button Manual and leave the event creation method set to default Single Event.
  5. Click + button to create a single event with three subcases and two channels.
  6. Drag and drop the three subcases (Front Torsional Stiffness, Rear Torsional Stiffness and Vertical Bending Stiffness) under Subcases of the newly created event.
  7. Set LDM to 0.1 and Scale to 3.0 for all three cases.
    Figure 14. Load Mapping to associate load-time history with static subcase
  8. Click Save to close the window and create the fatigue event using selected subcases and channels.
    Figure 15. Loading Sequences Definition
Submit the Job
Make sure the task Submit Analysis is selected in the Fatigue Analysis tree.
  1. From the Analysis page, enter the OptiStruct panel.
  2. Click save as following the input file field.
    The Save As dialog opens.
  3. For File name, enter the name SpotWeld_Cbar_Nugget_fat.fem.
  4. Click Save twice.
  5. For Run Option, select analysis.
  6. Click Submit.
    This launches OptiStruct to run the fatigue analysis.
    If the job was successful, new results files can be seen in the directory where the OptiStruct model file was written. The default files written to your directory are:
    SpotWeld_Cbar_Nugget_fat.hd3
    Hyper 3D binary results file, with both static analysis results and fatigue analysis results.
    SpotWeld_Cbar_Nugget_fat.out
    OptiStruct output file containing specific information on the file set up, the set up of your fatigue problem, compute time information, etc. Review this file for warnings and errors.
    SpotWeld_Cbar_Nugget_fat.stat
    Summary of analysis process, providing CPU information for each step during analysis process.
    Figure 16. Submit Fatigue Analysis
    Figure 17.
Post-process the Analysis
  1. Make sure the task Post-processing is selected in the Fatigue Analysis tree.
    When fatigue analysis has completed successfully after the previous submit, it will automatically go into this task.
  2. For Fatigue subcase, make sure Select Subcase is selected.
  3. For Result Type and Data Component, select the required data you want to contour from the drop-down menu.
  4. Click Load H3D Results (HV).
    This launches HyperView and loads the SpotWeld_Cbar_Nugget_fat.h3d results file. It applies the result contour for selected result type and component. You can use HyperView for more detailed results.
  5. Click Exit to unload Fatigue Process Manager.
    Figure 18. Post-Processing
    Figure 19. Damage Contour in HyperView
