/ACTIV
Block Format Keyword Describes the deactivation/activation of element groups.
| /ACTIV/activ_ID/unit_ID | |||||||||
| activ_title | |||||||||
| sens_ID | grbric_ID | grquad_ID | grshel_ID | grtrus_ID | grbeam_ID | grspr_ID | grsh3n_ID | Iform | |
| Tstart | Tstop | ||||||||
| activ_ID | Element deactivation block
identifier. (Integer, maximum 10 digits) |
| unit_ID | (Optional) Unit Identifier (Integer, maximum 10 digits) |
| activ_title | Element deactivation block
title. (Character maximum 100 characters) |
| sens_ID | Sensor
identifier. (Integer) |
| grbric_ID | Brick element group
| grquad_ID | Quad element group
| grshel_ID | Shell element group
| grtrus_ID | Truss element group
| grbeam_ID | Beam element group
| grspr_ID | Spring element group
| grsh3n_ID | 3N shell element group
| Iform | Formulation flag.
(Integer) |
| Tstart | Activation time for Iform=2. (Real) |
| Tstop | Deactivation time for Iform=2. Default = 1.0E+30 (Real) |
- Iform= 1: all elements
belonging to specified groups are deactivated when the sensor is activated (ON).
These elements are not deleted.
They may be reactivated when the sensor is deactivated - see /SENSOR criteria.
Iform=2:
All elements belonging to specified groups are activated when:- or if a sensor is given
ll elements belonging to specified groups are deactivated when:- or if a sensor is given
Where, is the sensor activation time.
- Deactivated elements must not belong to any rigid bodies.
