Materials
Law Name | Group | Type | Model Description | Application | Viscosity | Orthotrop | Embedded Thermal Option** | Strain Rate | Formulation |
/MAT/GAS* | Other materials | Gas | Gas molecular weight and specific heat coefficients | Airbag | No | No | Yes | No | Lagrange |
/MAT/PLAS_PREDEF | Elasto-plastic materials | Metal | Isotropic elasto-plastic material using the Johnson-Cook material model | Metals, elasto-plastic materials, mild steels, strain rate dependent, temperature dependent, isotropic and kinematic hardening, duroplaste, low alloy steel, ST52, and DP600 | No | No | Yes | Yes | Lagrange |
/MAT/LAW0 (VOID)* | Other materials | Void | Fictitious | Void material, visualization of surface/body/rigid materials as contact surfaces | No | No | No | No | Lagrange |
/MAT/LAW1 (ELAST)* | Other materials | Elastic | Isotropic, linear elastic material using Hooke's law | Metals and elastic materials for small deformation only | No | No | No | No | Lagrange |
/MAT/LAW2 (PLAS_JOHNS)* | Elasto-plastic materials | Metal | Isotropic elasto-plastic material using the Johnson-Cook material model | Metals, elasto-plastic materials, mild steels, strain rate dependent, temperature dependent, isotropic and kinematic hardening, duroplaste, low alloy steel, ST52, and DP600 | No | No | Yes | Yes | Lagrange |
/MAT/PLAS_ZERIL | Elasto-plastic materials | Metal | Isotropic elasto-plastic material using the Zerilli-Armstrong plasticity model | Metals, elasto-plastic materials, mild steels, strain rate dependent, temperature dependent, isotropic and kinematic hardening, duroplaste, low alloy steel, ST52, and DP600 | No | No | Yes | Yes | Lagrange |
/MAT/LAW3 (HYDPLA)* | Elasto-plastic materials | Hydrodynamic | von Mises hardening, polynomial pressure | Elasto-plastic materials in high speed impact, requires EOS | No | No | No | No | Lagrange |
/MAT/LAW4 (HYD_JCOOK)* | Elasto-plastic materials | Hydrodynamic | Hydrodynamic Johnson-Cook | Elasto-plastic materials in high speed impact, requires EOS, accounts for temperature effects | No | No | Yes | Yes | Lagrange |
/MAT/LAW5 (JWL)* | Multi-Materials, fluid and explosive materials | Explosive materials | Jones Wilkens Lee model | Explosive TNT | No | No | No | No | Lagrange Eulerian and ALE |
/MAT/LAW6 (HYDRO or HYD_VISC) * | Multi-Materials, fluid and explosive materials | Hydrodynamic | Hydrodynamic viscous | Fluid, gas, water and oil | Yes | No | No | No | Lagrange |
/MAT/K-EPS | Multi-Materials, fluid and explosive materials | CFD materials | Hydrodynamics viscous with | Yes | No | No | No | CFD | |
/MAT/LAW10 (DPRAG1)* | Concrete and Rock materials | Rock | Drucker-Prager for rock or concrete by polynomial | Soil, sand, simple concrete model, ice and snow | No | No | No | No | Lagrange |
/MAT/LAW11 (BOUND) | Multi-Materials, fluid and explosive materials | ALE materials | Boundary element | Inlet/outlet conditions for fluid | No | No | Yes | No | ALE |
/MAT/B-K-EPS | Multi-Materials, fluid and explosive materials | CFD materials | Boundary elements with | Inlet/outlet conditions for turbulent fluid | Yes | No | Yes | No | CFD |
/MAT/LAW12 (3D_COMP)* | Composite and Fabric materials | Composite | Tsai-Wu formula for solid | Laminated composite materials, carbon fiber laminates, and short fiber composite material | No | Yes | No | Yes | Lagrange |
/MAT/LAW14 (COMPSO)* | Composite and Fabric materials | Composite | Composite solid | Long fiber unidirectional composite materials | No | Yes | No | Yes | Lagrange |
/MAT/LAW15 (CHANG)* | Composite and Fabric materials | Composite | Composite Shell Chang-Chang | Laminated composite materials (Obsolete, use LAW25 or LAW12 instead). | No | Yes | No | Yes | Lagrange |
/MAT/LAW16 (GRAY)* | Elasto-plastic materials | Metal | Gray model | Allows for phase changes in high speed impact, not validated completely | No | No | Yes | Yes | Lagrange |
/MAT/LAW18 (THERM) | Multi-Materials, fluid and explosive materials | ALE materials | Purely thermal material | No | No | Yes | No | ALE | |
/MAT/LAW19 (FABRI)* | Composite and Fabric materials | Fabric | Fabric | Airbag and seat belt fabrics, woven fabric, seat foam cover, and materials without bending stiffness | No | Yes | No | No | Lagrange |
/MAT/LAW20 (BIMAT)* | Multi-Materials, fluid and explosive materials | ALE materials | ALE or Euler formulation | Mix of any 2 materials compatible with 2D analysis | No | No | No | No | ALE |
/MAT/LAW21 (DPRAG)* | Concrete and Rock materials | Rock | Drucker-Prager for rock or concrete by function | Soil and sand | No | No | No | No | Lagrange |
/MAT/LAW22 (DAMA)* | Elasto-plastic materials | Metal | Ductile damage for solids and shells | Metals, elasto-plastic materials, mild steels, strain rate dependent, duroplaste, low alloy steel, ST52, and DP600 | No | No | No | Yes | Lagrange |
/MAT/LAW23 (PLAS_DAMA)* | Elasto-plastic materials | Metal | Ductile damage for solids | Metals, elasto-plastic materials, mild steels, strain rate dependent, duroplaste, low alloy steel, ST52, and DP600 | No | No | No | Yes | Lagrange |
/MAT/LAW24 (CONC)* | Concrete and Rock materials | Rock | Brittle elastic plastic behavior of reinforced concrete | Sand, soil, concrete, ice and snow | No | No | No | No | Lagrange |
/MAT/LAW25 (COMPSH)* | Composite and Fabric materials | Composite | Composite Shell, plasticity model is based on standard (Tsai-Wu) formulation and CRASURV formulation | Laminated composite materials, carbon fiber laminates, and short fiber composite material | No | Yes | No | Yes | Lagrange |
/MAT/LAW26 (SESAM) | Multi-Materials, fluid and explosive materials | ALE materials | SESAM tabular EOS, used with a Johnson-Cook yield criterion | No | No | Yes | No | ALE | |
/MAT/LAW27 (PLAS_BRIT)* | Elasto-plastic materials | Brittle Metal and Glass | Aluminum, glass, etc. | Hard steel, Dualphase steel, DP800, DP1000, casting, aluminum, magnesium, poly carbonate, and glass | No | No | No | Yes | Lagrange |
/MAT/LAW28 (HONEYCOMB)* | Honeycomb materials | Honeycomb | Honeycomb | Honeycomb and corrugated cardboard | No | Yes | No | No | Lagrange |
/MAT/USERij | Other materials | User-defined | User-defined | User-defined | No | No | No | No | Lagrange |
/MAT/LAW32 (HILL)* | Elasto-plastic materials | Metal orthotropic | Hill | Aluminum alloy, anisotropic steel, and roll formed metals | No | Yes | No | Yes | Lagrange |
/MAT/LAW33 (FOAM_PLAS)* | Hyper and visco-elastic materials | Foam | Closed cells, elastic plastic foam | Crushable foam and styrofoam | Yes | No | No | No | Lagrange |
/MAT/LAW34 (BOLTZMAN)* | Hyper and visco-elastic materials | Visco-elastic | Boltzmann | Viscous foams, rubbers, and creep behavior | Yes | No | No | No | Lagrange |
/MAT/LAW35 (FOAM_VISC)* | Hyper and visco-elastic materials | Foam | Generalized Kelvin-Voigt | High density foam with viscosity | Yes | No | No | No | Lagrange |
/MAT/LAW36 (PLAS_TAB)* | Elasto-plastic materials | Metal | Tabulated piecewise linear | Elasto-plastic material | No | No | No | Yes | Lagrange |
/MAT/LAW37 (BIPHAS)* | Multi-Materials, fluid and explosive materials | ALE materials | Hydrodynamic bi-material liquid gas material | Liquid and gas | Yes | No | No | No | ALE |
VISC_TAB* | Hyper and visco-elastic materials | Viscous | Tabulated law | Viscous foams and seat foam | Yes | No | No | Yes | Lagrange |
/MAT/LAW40 (KELVINMAX)* | Hyper and visco-elastic materials | Viscous | Generalized Maxwell-Kelvin | Visco-elastic foams and rubber | Yes | No | No | No | Lagrange |
/MAT/LAW41 (LEE_TARVER)* | Multi-Materials, fluid and explosive materials | Hydrodynamic | Lee_Tarver material | Explosives | No | No | Yes | No | Lagrange |
/MAT/LAW42 (OGDEN)* | Hyper and visco-elastic materials | Rubber | Hyper visco-elastic | Incompressible rubber materials | Yes | No | No | No | Lagrange |
/MAT/LAW43 (HILL_TAB)* | Elasto-plastic materials | Metal | Hill (tabulated) | Aluminum alloy, anisotropic steel, and roll formed metals | No | Yes | No | Yes | Lagrange |
/MAT/LAW44 (COWPER)* | Elasto-plastic materials | Metal | Cowper-Symonds | Metals, elasto-plastic materials, mild steels, strain rate dependent, temperature dependent, isotropic and kinematic hardening, duroplaste, low alloy steel, ST52, and DP600 | No | No | No | Yes | Lagrange |
/MAT/LAW46 (LES_FLUID)* | Multi-Materials, fluid and explosive materials | CFD materials | Viscous fluid with LES subgrid scale viscosity | Yes | No | No | No | CFD | |
/MAT/LAW48 (ZHAO)* | Elasto-plastic materials | Metal | Elastic plastic strain rate dependent materials | Metals, elasto-plastic materials, mild steels, strain rate dependent, temperature dependent, isotropic and kinematic hardening, duroplaste, low alloy steel, ST52, and DP600 | No | No | No | Yes | Lagrange |
/MAT/LAW49 (STEINB)* | Elasto-plastic materials | Hydrodynamic | Steinberg-Guinan | No | No | Yes | No | Lagrange | |
/MAT/LAW50 (VISC_HONEY)* | Honeycomb materials | Composite | Crushable foam | Honeycomb and corrugated cardboard | Yes | Yes | No | Yes | Lagrange |
/MAT/LAW51 (MULTIMAT)* | Multi-Materials, fluid and explosive materials | ALE materials | Solid, liquid, gas and explosives | Fluid, gas, water, oil, metals, explosive, soil, and sand | Yes | No | Yes | Yes | ALE |
/MAT/LAW52 (GURSON)* | Elasto-plastic materials | Metal | Ductile damage for porous materials, Gurson | Castings alloys, aluminum, adhesives, cast iron, and cast aluminum (material with void inclusions) | Yes | No | No | Yes | Lagrange |
/MAT/LAW53 (TSAI_TAB)* | Elasto-plastic materials | Composite | Orthotropic elasto-plastic | No | Yes | No | No | Lagrange | |
/MAT/LAW54 (PREDIT)* | Connections materials | Spotweld | Predit law | No | No | No | No | Lagrange | |
/MAT/LAW57 (BARLAT3)* | Elasto-plastic materials | Metal | Three-parameter Barlat | DC04 and anisotropic steel | No | Yes | No | Yes | Lagrange |
/MAT/LAW58 (FABR_A)* | Composite and Fabric materials | Fabric | Fabric | Airbag and seat belt fabrics, woven fabric, seat foam cover, Kevlar, materials without bending stiffness, and material for draping simulations | No | Yes | No | No | Lagrange |
/MAT/LAW59 (CONNECT)* | Connections materials | Spotweld | Connection material | Spotwelds, adhesives, rivets, and bonding layers for laminates | No | No | No | Yes | Lagrange |
/MAT/LAW60 (PLAS_T3)* | Elasto-plastic materials | Metal | Tabulated quadratic in strain rate | Elasto-plastic material, low alloy mild steel, DP780, ultra-hard steel, Boron steel, 22MnB5, aluminum, AA5182, AA6061, AA6070, Thermoplast, EPDM, Polyamid, HCT, HCT600, Noryl, PA6GF30, and polypropylen | No | No | No | Yes | Lagrange |
/MAT/LAW62 (VISC_HYP)* | Hyper and visco-elastic materials | Rubber | Hyper visco-elastic | Compressible & incompressible rubber, and foams | Yes | No | No | Yes | Lagrange |
/MAT/LAW63 (HANSEL)* | Elasto-plastic materials | Metal | Hansel model | Austenitic steel and account for solid phase change (obsolete, use LAW80 instead). | No | No | Yes | No | Lagrange |
/MAT/LAW64 (UGINE_ALZ)* | Elasto-plastic materials | Elastic plastic Isotropic | Ugine & Alz approach | Austenitic steel and account for solid phase change (obsolete, use LAW80 instead). | No | No | Yes | No | Lagrange |
/MAT/LAW65 (ELASTOMER)* | Elasto-plastic materials | Elastic plastic Isotropic | Elastomer | Seat belts and Nitinol | No | No | No | Yes | Lagrange |
/MAT/LAW66* | Elasto-plastic materials | Rubber | Visco-elastic | Magnesium, polymer, and steel | Yes | No | No | Yes | Lagrange |
/MAT/LAW68 (COSSER)* | Honeycomb materials | Honeycomb | Cosserat Medium | Honeycomb and corrugated cardboard | No | Yes | No | No | Lagrange |
/MAT/LAW69* | Hyper and visco-elastic materials | Rubber | Tabulated Input for hyperelastic | Incompressible rubber materials | No | No | No | No | Lagrange |
/MAT/LAW70 (FOAM_TAB)* | Hyper and visco-elastic materials | Foam | Tabulated law, hyper visco-elastic | Compressible foams, PU, EPP, and PVC | Yes | No | No | Yes | Lagrange |
/MAT/LAW71* | Other materials | Metal (shape memory alloy) | Analytical pseudo elastic | Shape memory alloy - Nitinol | No | No | Yes | No | Lagrange |
/MAT/LAW72 (HILL_MMC)* | Elasto-plastic materials | Metal | Anistropic Hill | Anisotropic steel, Anisotropic aluminum, AA6061 T6, and DP780 | No | Yes | No | No | Lagrange |
/MAT/LAW73* | Elasto-plastic materials | Metal | Thermal Hill Orthotropic | Metal forming applications | No | Yes | Yes | Yes | Lagrange |
/MAT/LAW74* | Elasto-plastic materials | Metal | Thermal Hill Orthotropic 3D | Metal forming applications | No | Yes | Yes | Yes | Lagrange |
/MAT/LAW75 (POROUS)* | Other materials | Foam | Porous material model | Ductile porous | No | No | No | No | Lagrange |
/MAT/LAW76 (SAMP)* | Elasto-plastic materials | Plastic | Semi-analytical elasto-plastic | Plastic, polymer, and high alloy steel | No | Yes | No | Yes | Lagrange |
/MAT/LAW77* | Hyper and visco-elastic materials | Foam | Tabulated law, visco-elastic foam | Open cell foam | Yes | No | No | Yes | Lagrange |
/MAT/LAW78* | Elasto-plastic materials | Plastic strain | Yoshida-Uemori material | DC04, anisotropic steel, deep drawing, and stamping steel | No | Yes | No | No | Lagrange |
/MAT/LAW79 (JOHN_HOLM)* | Elasto-plastic materials | Brittle Metal and Glass | Brittle metals | Ceramics and glass | No | No | No | Yes | Lagrange |
/MAT/LAW80* | Elasto-plastic materials | Metal | High strength steel | Ultra high strength steel (Boron), Hot forming, solid phase change (from austenite to bainite, perlite, ferrite, martensite) | No | No | Yes | Yes | Lagrange |
/MAT/LAW81* | Concrete and Rock materials | Rock | Drucker-Prager with cap | Soils | No | No | No | No | Lagrange |
/MAT/LAW82* | Hyper and visco-elastic materials | Rubber | Ogden material | Incompressible rubber materials | No | No | No | No | Lagrange |
/MAT/LAW83* | Connections materials | Spotweld | Advanced connection material | Spotwelds, adhesives, rivets, and bonding layers for laminates | No | No | No | Yes | Lagrange |
/MAT/LAW84* | Elasto-plastic materials | Metal | Swift and Voce elasto-plastic law | No | Yes | Yes | Yes | Lagrange | |
/MAT/LAW87 (BARLAT2000)* | Elasto-plastic materials | Metal | Anisotropic Barlat
Yield 2000 criterion Swift and Voce elasto-plastic law, or Tabulated law |
Anisotropic metals, especially aluminum | No | Yes | No | Yes | Lagrange |
/MAT/LAW88* | Hyper and visco-elastic materials | Rubber | Simpified hyperelastic material | Rubber, foam | Yes | No | No | Yes | Lagrange |
/MAT/LAW90* | Hyper and visco-elastic materials | Foam | Tabulated law, hyper visco-elastic | Compressible foams, PU, EPP, and PVC | Yes | No | No | Yes | Lagrange |
/MAT/LAW92* | Elasto-plastic materials | Rubber | Arruda-Boyce hyperelastic material | Incompressible rubber materials | No | No | No | No | Lagrange |
/MAT/LAW93 (ORTH_HILL) or (CONVERSE)* | Elasto-plastic materials | Metal | Orthotropic elastic material with Hill plasticity | Metal, plastic | No | Yes | Yes | Yes | Lagrange |
/MAT/LAW94 (YEOH)* | Hyper and visco-elastic materials | Rubber | YEOH hyperelastic material | Rubber, plastic | No | No | Yes | No | Lagrange |
/MAT/LAW95 (BERGSTROM_BOYCE)* | Hyper and visco-elastic materials | Rubber | BERGSTROM-BOYCE nonlinear visco-elastic material | Predicting the nonlinear time dependency of elastomer | Yes | No | No | Yes | Lagrange |
/MAT/LAW97 (JWLB)* | Hydrodynamic and explosive materials | Explosive materials | Jones Wilkins Lee Baker Material | Explosive TNT | No | No | No | No | Lagrange Eulerian and ALE |
/MAT/LAW100 (MNF)* | Hyper and visco-elastic materials | Rubber | Polynomial form, Arruda Boyce, Neo Hook, Mooney-Rivlin, Yeoh and Neo Hook with temperature dependency and Nonlinear viscoelastic material | Predicting the nonlinear time dependency of elastomer | Yes | No | No | Yes | Lagrange |
/MAT/LAW101* | Hyper and visco-elastic materials | Thermoplastic polymers | Time and temperature dependent material model for thermoplastics | Polypropylene materials | Yes | No | Yes | Yes | Lagrange |
/MAT/LAW102 (DPRAG2)* | Concrete and Rock materials | Rock | Drucker-Prager for rock or concrete by polynomial | Soil, sand, and simple concrete model | No | No | No | No | Lagrange |
/MAT/LAW103 (HENSEL-SPITTEL)* | Elasto-plastic materials | Metal | Isotropic elastic-plastic material at high temperature using Hensel-Spittel yield stress formula | Metal | No | No | Yes | No | |
/MAT/LAW104 (JOHNS_VOCE_DRUCKER)* | Elasto-plastic materials | Metal | Elasto-plastic with mixed Voce and linear hardening | Dual phase steel sheet metal | No | No | Yes | Yes | Lagrange |
/MAT/LAW106 (JCOOK_ALM)* | Elasto-plastic materials | Metal | Isotropic elasto-plastic material using the Johnson-Cook material model with temperature dependent Young’s modulus and Poisson’s ratio | Metal | No | No | Yes | No | Lagrange |
/MAT/LAW108 (SPR_GENE)* | Springs | Zero length spring material with six degrees of freedom. Includes nonlinear stiffness, damping and different unloading | Connections | No | No | Lagrange | |||
/MAT/LAW109* | Elasto-plastic materials | Metal | Elasto-plastic material with isotropic von Mises yield criterion with plastic strain rate and temperature depending nonlinear hardening. | Metal | No | No | Yes | Yes | Lagrange |
/MAT/LAW110 (VEGTER)* | Elasto-plastic materials | Metal | Elasto-plastic constitutive law using the interpolated yield criterion of Corus-Vegter and the hardening law of Vegter, accounting for strain-rate dependency and thermal effect. | Metal | No | No | Yes | Yes | Lagrange |
/MAT/LAW111* | Hyper and visco-elastic materials | Rubber | Marlow material model, support tabulated input for hyperelastic. | Incompressible rubber materials | No | No | No | No | Lagrange |
/MAT/LAW112 (PAPER or XIA)* | Orthotropic and dissymmetric elasto-plastic material | Paperboard | Fully uncouple the behavior in the plane of the paper sheet and the behavior out of the plane. A yield stress is defined for each directions of loading, in tension and compression. | Paperboard | No | No | No | Yes | Lagrange |
/MAT/LAW113 (SPR_BEAM)* | Springs | Beam type spring material with six independent modes of deformation. Includes nonlinear stiffness, damping and different unloading. | Connections | No | No | Lagrange | |||
/MAT/LAW114 (SPR_SEATBELT) | 1D seatbelt material | Seatbelt material | Elastic nonlinear elastic with different loading and unloading behavior | Seatbelt | No | No | No | No | Lagrange |
/MAT/LAW115 (DESHFLECK)* | Elasto-plastic material | Metal | Mises criterion with pressure dependence. | Fleck foam | No | No | No | No | Lagrange |
/MAT/LAW116* | Connections materials | Cohesive material | Mixed mode, strain rate dependent material model with damage and failure | Adhesive layer and bonding layers for laminates | No | No | No | Yes | Lagrange |
/MAT/LAW117* | Connections materials | Cohesive material | Ductile adhesive materials in 2 modes for normal and tangential directions | Adhesive layer and bonding layers for laminates | No | No | No | No | Lagrange |
/MAT/LAW119 (SH_SEATBELT) | 2D seatbelt material | Seatbelt material | Elastic nonlinear elastic with different loading and unloading behavior | Seatbelt | No | No | No | No | Lagrange |
/MAT/LAW121 (PLAS_RATE) | Elasto-plastic materials | Metal | Elasto-plastic strain rate dependent material with isotropic von Mises yield criterion | Metal | No | No | No | Yes | Lagrange |
/MAT/LAW151 (MULTIFLUID)* | Hydrodynamic and explosive materials | ALE / EULER materials | Compressible multi-material | Fluid, gas, water and oil | No | N/A | No | N/A | Eulerian and ALE |
/MAT/LAW200 (MDS) | Multiscale Design materials | Many material types | Link to Multiscale Designer material law | Many material types | Yes | Yes | Yes | Yes | Lagrange |
(*): Indicates material laws compatible with local unit system
(**): Besides materials that already have thermal characteristics inside material law (Embedded Thermal Option), all material laws could define thermal characteristics with /HEAT/MAT, Thermal expansion which defined with /THERM_STRESS/MAT is available for all material laws with shell element and the following materials with solid elements:
Material laws where the number goes from 1 to 28 and laws number 36, 42, 44, 45, 46, 47, 48, 49, 50, 56, 60, 62, 65, 66, 68, 69, 72, 74, 79, 81, 82, 88, 90, 92, 93, 94, 95, 100, 102, 103, 106.
- For shell elements with /MAT/LAW66 and /MAT/LAW25 (COMPSH) and solid elements with /MAT/LAW42 (OGDEN), /MAT/LAW69, /MAT/LAW82, /MAT/LAW92 and /MAT/LAW103 (HENSEL-SPITTEL), it is possible to use /VISC/PRONY to describe viscosity.
- All characters beyond the 8th of a keyword are ignored (for example, it is possible to input HONEYCOM, instead of HONEYCOMB).
- The Manual Keyword is the keyword of the law, as referenced in this manual.
- The Law Number is the material law number used to reference the material law in the fixed format manual.
- The Other Available Keywords column features other keywords, which can be used to define the same material law.
