/ANIM/GZIP
Engine Keyword Generates animation files in GZIP format.
/ANIM/GZIP
- Only available on platforms that support GZIP.
View new features for Radioss 2022.1.
Radioss format 2022 uses the 12x extension format.
Engine Keyword In this group of keywords are used to generally define the output style, control of computation, damping and ALE setup during the computation.
Engine Keyword In this group, keywords are used for modification (deletion or add options) in Engine.
Generates animation files containing results according to the keywords specified. The keywords are specified in the topics within Animation and Post-processing Output Files.
Engine Keyword Write animation files (A-files) at a time frequency equal to Tfreq, the first file being written at time Tstart. The animation file name will be RunnameAnnn where Runname is the Run Name and nnn is the file number.
Engine Keyword Write additional animation files (Animation Output File (A-File)) when a sensor in the list is activated.
Engine Keyword Generates animation files with one part for each material.
Engine Keyword Write additional animation files (Animation Output File (A-File)) with a time frequency equal to Tfreq, the first file being written once sensor activated. (The activation of sensor will be defined in /SENSOR).
Engine Keyword Write additional name description to the animation file content.
Engine Keyword
Engine Keyword
Engine Keyword In this group keywords are used for implicit solution. Different implicit solver methods (linear, nonlinear, buckling or quasi-static), different options to control the implicit computation, different implicit time step method and implicit output messages are introduced.
Engine Keyword In this group, keywords are used to define the kinematic condition (constrain/release rotation or translation DOF) and initial condition (rotational/translational velocity).
Engine Keyword In this group, keywords are used to define different time step control (STOP, KILL, CST or DEL, etc.) for different entities (shell, brick, beam, airbag, interface, etc.) during the computation.
Engine Keyword In this group, keywords are used to output different info (like stress, strain, orthotropy direction, temperature, etc.) in state file (STA-File).
Engine Keyword Keywords that are still supported, but no longer maintained (*) are considered obsolete.
This manual contains an alphabetical list of LS-DYNA input files available in Radioss.
This manual contains the description of the Keywords for the Radioss Multi-Domain.
/ANIM/GZIP
