Obsolete
Engine Keyword Keywords that are still supported, but no longer maintained (*) are considered obsolete.
(*) A keyword can become obsolete for several reasons:
  • Overtaken by a new and more powerful keyword
  • No longer used
  • Devel dismissed
Note: Obsolete keywords will continue to be supported, but they may no longer be exposed in upcoming versions of the manual. Also, new keyword are recommended, instead of obsolete keyword.
Below is a list of Obsolete Engine keywords:
Obsolete Keywords As of Version Replaced with New Keyword
/ALE/0 (or /ALE) v12.0.210
/ALE/2 v12.0.210 /ALE/SPRING
/ALE/3 v12.0.210 /ALE/ZERO
/ALE/4 v12.0.210 /ALE/STANDARD
/ANIM/KEEPD v13.0
/SHVER/V51 v13.0
/VEL/ALE v13.0
/ALE/DISP v14.0.220 /ALE/GRID/DISP
/ALE/DONEA v14.0.220 /ALE/GRID/DONEA
/ALE/SPRING v14.0.220 /ALE/GRID/SPRING
/ALE/STANDARD v14.0.220 /ALE/GRID/STANDARD
/ALE/ZERO v14.0.220 /ALE/GRID/ZERO
/ALESUB v2018
/ANIM/CUT/1 v2018
/ANIM/CUT/2 v2018
/ANIM/CUT/3 v2018
/INCMP v2018
/UPWIND v2018 /ALE/MUSCL
/UPWM/SUPG v2018 /ALE/SUPG/OFF
/UPWM/TG v2018
/MADYMO/ON v2021.2
/IMPL/DYNA/FSI 2022.1
/DT/GLOB/Iflag 2022.1
