/CNODE
Block Format Keyword Defines the coordinate of common node, which could be merged to the nearest selected NODE or CNODE.
/CNODE/search_value/unit_ID | |||||||||
cnode_ID | Xc | Yc | Zc |
search_value | Distance around each CNODE
in order to find the nearest NODE or CNODE. (Real) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
cnode_ID | Common node
identifier. (Integer) |
Xc | X
coordinate. (Real) |
Yc | Y
Zc | Z
- Node identifier is arbitrary; but can not be the same as an existing NODE identifier.
- Common nodes may be defined with more than one block.
- Common node identifiers are arbitrary and can not be the same as a NODE.
- The CNODE will be merged to the nearest selected NODE or CNODE.
- The CNODE merging will be done after each model transformation (Transforms).
- In case a CNODE cannot be merged to any NODE or CNODE, it will be replaced by NODE.
