/DEF_SHELL
Block Format Keyword This keyword is used to set default values for certain parameters in all shell properties, but options could still be changed in each property set input and in this case, the latter will prevail.
| /DEF_SHELL | |||||||||
| Ishell | Ismstr | Ithick | Iplas | Ish3n | Idril | ||||
| Ishell | Shell element formulation
flag.
(Integer) |
| Ismstr | Shell small strain
formulation flag.
(Integer) |
| Ithick | Shell resultant stresses
calculation flag.
(Integer) |
| Iplas | Shell plane stress
plasticity flag.
(Integer) |
| Istrain | Compute strains for
post-processing flag.
(Integer) |
| Ish3n | 3-node shell element
formulation flag.
(Integer) |
| Idril | Drilling DOF stiffness flag.
(Integer) |
- This card is read only once. Only the first card /DEF_SHELL written in the model is used. The other card /DEF_SHELL is ignored.
- Refer to the comments in /PROP/TYPE1 (SHELL) for more information about these input options.
