/DRESP1
Optimization Keyword Defines a response or a set of responses that are a result of a design analysis iteration. These responses can be used to drive the optimization process and are a measure of how a model performs under a set of constraints, boundary conditions and loading. They can be used as a design objective or as design constraints.
| /DRESP1/resp_ID | |||||||||
| title | |||||||||
| RTYPE | PTYPE | REGION | ATTA | ATTB | ATTI | ATTJ | |||
| resp_ID | Design response
identifier. (Integer > 0) |
| title | Title. (Character, maximum 100 characters) |
| RTYPE | Response type for an
optimization run.
(Integer > 0) |
| PTYPE | Entity type for the
definition of the optimization response.
(Integer > 0 or blank) PTYPE can be blank only when RTYPE=1, 2, 3, 4 or 8, which implies that the response is defined on the entire model. |
| REGION | Region
identifier. Default = 0 (Integer ≥ 0) |
| ATTA | Attributes of a response
where further definition is required. 1 Default = 0 (Integer ≥ 0) |
| ATTB | Attributes of a response
| ATTI | Identification number of a
group of entities for which the response is defined. If PTYPE = 1: node group identifier If PTYPE = 2: element group identifier If PTYPE = 3: part group identifier (Integer > 0 or blank) |
| ATTJ | Additional definition of
the entity type (only needed when
PTYPE=2)
/DRESP1/1
Response is mass summary of part group ID 2000329
### RTYPE=1: Mass
### PTYPE=3: Part
### ATTB=1 : SUM (summary)
### ATTI=2000329 : 2000329 is part group identifier due to PTYPE = 3
# RTYPE PTYPE REGION ATTA ATTB ATTI
1 3 2 2000329
/DRESP1/2
Response is Y translational displacement of node group ID 2021524
### RTYPE=5: Displacement
### PTYPE=1: Node
### ATTA=2 : Displacement component of Translational Y
### ATTI=2021524 : 2021524 is node group identifier due to PTYPE = 1
5 1 2 2021524
#---1----|----2----|----3----|----4----|----5----|----6----|----7----|----8----|----9----|---10----| Comments
- Response and
Entity type table.
Response Type (RTYPE) Entity type (PTYPE) ATTA ATTB Mass (1) Part (3) or blank - =2: SUM Or blank
Fraction of mass (2) Part (3) or blank - =1: COMB =2: SUM
Or blank
Volume (3) Part (3) or blank - =2: SUM Or blank
Fraction of design volume (4) Part (3) or blank - =1: COMB =2: SUM
Or blank
Displacement (5) Node (1) Displacement component code. 2 - Stress (6) Element (2), Part (3) Stress item code. 3 >0: Cluster size Or blank
Strain (7) Element (2), Part (3) Strain item code - Internal strain energy (8) Part (3) or blank - =2: SUB Or blank
Velocity (9) Node (1) Velocity component code. 2 - ATTA for Displacement and Velocity component code.
ATTA Value Displacement Component 1 Translational X 2 Translational Y 3 Translational Z 4 Rotational X 5 Rotational Y 6 Rotational Z 7 Total displacement 8 Total rotation - ATTA for stress/strain item
code.TRUSS elements:
ATTA Value Stress/Strain Item 0 or blank Both ends 1 End A 2 End B Beam elements:ATTA Value Stress/Strain Item 0 or blank All stresses/strains 4 End A pt. C 5 End A pt. D 6 End A pt. E 7 End A pt. F 104 End B pt. C 105 End B pt. D 106 End B pt. E 107 End B pt. F 8 Max end A 108 Max end B All Solid elements:ATTA Value Stress/Strain Item 13 von Mises 101* Max Principal Stress 8 Major Principal 16 Mid Principal 22 Minor Principal 6 Normal X 14 Normal Y 20 Normal Z 7 Shear XY 15 Shear YZ 21 Shear XZ 102* Equivalent Plastic Strain (for strain response only) All Shell elements:ATTA Value Stress/Strain Item 101* von Mises both surfaces 102* Major Principal both surfaces 9 von Mises 1 17 von Mises 2 7 Major Principal 1 15 Major Principal 2 103* Minor Principal both surfaces 8 Minor Principal 1 16 Minor Principal 2 104* Normal X both surfaces 3 Normal X 1 11 Normal X 2 105* Normal Y both surfaces 4 Normal Y 1 12 Normal Y 2 106* Shear XY both surfaces 5 Shear XY 1 13 Shear XY 2 107* Equivalent Plastic Strain both surfaces 108* Equivalent Plastic Strain 1 109* Equivalent Plastic Strain 2 Note: ATTA values marked with an asterisk (*) are not consistent with OptiStruct.
