/DVPREL1
Optimization Keyword Linearly relates a design variable to an analysis model property.
/DVPREL1/dvp_ID | |||||||||
title | |||||||||
prop_typ | prop_ID | prop_fid | C0 | ||||||
DVID1 | COEF1 | ||||||||
DVID2 | COEF2 | ||||||||
etc | etc | ||||||||
DVIDN | COEFN |
dvpl_ID | Identification
number. (Integer > 0) |
title | Title. (Character, maximum 100 characters) |
prop_typ | Property type. The
type is specified immediately after the corresponding
/PROP, as: 1
(Integer ≥ 0) |
prop_ID | Property identifier
(/PROP/...). (Integer > 0) |
prop_fid | Property field
identifier to be related with design variable. Depending on
various property types (prop_typ), the
available options are different. 1 (Integer > 0) |
C0 | Constant in the
equation that defines the relationship between the design
variable and the property. Default = 0.0 (Real) |
DVIDi | Design variable
identifier (/DESVAR) that is related to the property. No default (Integer > 0) |
COEFi | Coefficient in the
variable and the property. Default = 1.0 (Real) |
/DVPREL1/1
related design variable
### Related design variable to design variable identifier 1 (defined in /DEVSVAR) is thickness of shell property ID 2000329 (which defined with /PROP/SHELL)
### prop_typ=1: property type is /PROP/SHELL
### prop_ID=2000329 : property identifier is 2000329
### prop_fid=1: Thickness due to prop_typ=1
### DVID1=1: Design variable identifier (/DESVAR) is 1
# prop_typ prop_ID prop_fid C0
1 2000329 1 0.0
# DVID1 COEF1
1 1.0
- The specific property field ID's that are
related to the design variables are listed based on the following property
types:prop_type = 1 (/PROP/SHELL):
prop_fid 1 = Thick prop_type = 2 (/PROP/TRUSS):prop_fid 1 = Area prop_type = 3 (/PROP/BEAM):prop_fid 1 = Area 2 = Iyy
3 = Izz
4 = Ixx
prop_type = 11 (/PROP/SH_SANDW):prop_fid > 0 = Ply Thickness < 0 = Ply Orientation Angle
- This card is represented as an optimization design variable in HyperMesh and HyperCrash.
