/PROP/TYPE29, /PROP/TYPE30 or /PROP/TYPE31
Block Format Keyword Describes the user's property set.
/PROP/TYPE29/prop_ID, /PROP/TYPE30/prop_ID or /PROP/TYPE31/prop_ID | |||||||||
prop_title |
prop_ID | Property
prop_title | Property
- Type USER1 (TYPE29), USER2 (TYPE30), and USER3 (TYPE31) are properties that may be created by you.
- User Types can only be affected to solid or spring elements.
- For Program User Properties, contact Altair Development France.
