Quasi-Compressible Option
For a quasi-compressible option, density and energy are assumed to be constant.
Therefore, the performance is improved and less computation time is needed.
The quasi-compressible option can be activated in the Radioss Engine file by /INCMP.
Using this option, the acoustic waves propagate as accurately as in the compressible case. However, it cannot be combined with the turbulence model.
