RD-T: 3150 Seat Model with Dummy
This tutorial presents the different steps involved in building a simple Sled model using HyperCrash pre-processing tool.
Model Files
Start HyperCrash
- Open HyperCrash.
- Set the User profile to RadiossV2022 and the Unit system to N_mm_s_T.
- Set User Interface style as New.
- Set your working directory to where the downloaded file is located.
- Click Run.
- Click File > Import > Radioss.
- In the input window, select SEAT__00D00.rad.
- Click OK.
Merge Models
Figure 1.A HyperCrash message window prompt appears. - Click Merge.
- Select the file FLOORD00.rad.
- Click OK.
- In the Set all to field, enter the value 100000.
Click the Set all to button to offset the numbering of
all the entities.
Figure 2. - Click Merge to merge the floor model.
Redo the steps 1 to 7 for the cushion model:
File:
- FOAMD00.rad
- Set all to offset: 200000
Redo the steps 1 to 7 for the seatbelt model:
File:
- BELTD00.rad
- Set all to offset: 300000
Set Model Hierarchy
- Click the Tree tab and select the subset of the seat named Seat model (300005).
Right-click and select Change Name.
Figure 3. - In the Change Name window, enter the name Seatbelt.
- Click Ok.
- Click any item on the tree, right-click and select New Assembly.
- Enter the name Frame and click Ok.
- Select the parts Seat plate, Backseat plate, Feet, Seat frame, and Backseat frame using the Shift or Ctrl keys.
- Press and hold the middle mouse button and drag the selected parts into the new assembly Frame.
- Select the Tree root (Seat) and right-click.
In the pop-up menu, select List Selection.
Figure 4.The List Selection dialog opens. - In the displayed window, check if all parts have properties (PID) and materials (MID).
- Click Close > Export the model to save.
Connect Models
Click Mesh Editing > Rigid Body.
Figure 5. - Select the rigid body: Floor.
Click See selected rigid bodies (
Click Display All
and then Left View (F11).
Right-click in the Grnod_Id entry box and click
Select in graphic, click
Add nodes by box selection and select all the nodes of the seat, feet and the anchorage points of the seatbelt.
- Right-click to validate.
Select the Floor rigid body in the list, right-click and
add the rigid body and main node to time history.
Figure 6.
Connect Seat Cushion to Seat Frame
- Click LoadCase > Contact Interface.
- Right-click in the window and select Create New > Kinematic condition (Type 2).
Display only the cushion parts. Press F11 for XZ view,
select Secondary nodes section, and click
Add noes by box selection.
Holding down the Shift key, click to draw a polygon
window around nodes on the backside of cushion of the nodes.
Tip: Press the letter P for non-perspective view, if needed.
Press Shift and draw a closed polygon window around the nodes to select. When finished, release the Shift key.
Display Frame Assembly in the Tree, pick Main surface
section, click
Add/Remove a face and pick one element on each part of the frame facing the cushion. Then select the Expand option on the lower right corner to pick select all.
- Select the Expand option on the lower right corner to select all the elements of the seat assembly facing the seat cushions.
Click Yes or Enter on the
keyboard to end the selection.
Figure 7. - For the Title of the contact, enter seat cushion fixation.
- Click Save.
Click
at the top of the interface panel, to check the interface.
Figure 8.The created interface should be displayed with green text. Otherwise, the interface has to be modified. - Click Close.
- Click Export to save the model.
Position the Dummy
Click Safety > Dummy Positioner.
Figure 9. -
From the Dummy model list menu, select New dummy.
Figure 10.A DummyMng panel opens. - Select the File subpanel.
Select the file H350R12BD00.
Figure 11.The dummy model is displayed in the small graphic window. - Click Validate.
- Set Set all to value to 400000.
- Click the Set all to button to offset the numbering of all entities.
- Click OK to merge the Dummy model.
Click Import in the dummy positioning window and select
the file H350R12B_Position.M00 and click
OK.
H350R12B_Position.M00 contains all parameters for the automatic dummy positioning.
Figure 12. - Close the Dummy positioner and click Export to save the model.
Add the Seatbelt
- Click Safety > Belt Generator.
Enter the name Upper belt and click
OK to validate.
Figure 13. -
Click Seat belt reference points (
Click Add nodes by picking (
) and select three nodes, as shown in the following image (red dots).
Figure 14. - Click Yes on the right corner and OK to validate the node selection.
Click Add/Remove body parts (
) and select the parts: torso, pelvis, upper legs, and the seat cushion fabric, as shown in red in the image.
Figure 15. - Click Yes to validate the selection.
- Set the Gap value to 5.00 mm.
- Set the Belt geometric width to 40.
- Set the Element Size to 8.
Click Material (
) and select the material file BELT.mat you saved to your working directory.
- Click OK.
Click Property (
) and select the property file BELT.prop you saved to your working directory.
- Click OK.
- Click Preview to display the proposed seat belt. Some intersections may exist between the seat cushion and the seat belt.
- Use the orientation tools to modify the angle of the Rigid Body 2.
Figure 16.
Figure 17. - Click Save to save the belt definition.
Redo the same operations in order to create the lower
belt. Select nodes, as shown below.
Figure 18. - Select the parts: pelvis, upper legs and seat cushion fabric.
Click Preview > Save > Close.
Figure 19. - Click Export to save the model.
Seatbelt versus Dummy
Create Contact Interfaces
During the seatbelt creation, two contact interfaces between the seatbelt and the dummy have been created. You will need to check and remove any remaining intersections and penetrations.
- Select interface BELT ID 400038.
Click See selected (
) to display.
Click in Main Surface, right-click in the modeling window, and click
Include picked parts to select the Fabric backframe and the Backseat frame as they may come into contact with the shoulder belt during the analysis.
Figure 20. - Click Save.
- Select interfaces BELT ID 400038 and BELT ID 400039.
) to display.
- Set Coulomb friction to 0.3.
- Set Friction penalty formulation to 2.
- Click Save.
Click Check penetration selected interfaces (
In the Quality panel, remove the intersections and penetrations using the
Depenetrate Auto (
- Click Close in order to come back to the Contact Interface panel.
Create Seat Structure
Creation of Self-Impact between different parts of the Seat.
- In the Tree window, select subsets Frame, Floor and Foam.
Click the Isolate icon
Figure 21. - Right-click in the Contact list and select Create New Multi-usage (Type 7).
- Click Self impact.
- Set the Title to Self impact seat structure.
- Set Gap/element option to Variable gap.
- Set Coulomb friction to 0.2.
Right-click in the Main Surface entry box and click Select in graphics > Add selected parts of tree (
- Click Save.
- Select the self impact seat structure interface in the list.
). Some penetrations exist between the seat cushion and the seat structure.
- Switch to the Tree window, and select the subset named Frame.
Switch to the Quality window and click Fixed part
- Press the Esc key to remove all selected parts.
Click Add selected parts of tree (
Click Depenetrate Auto (
Note: Only the nodes of the seat cushion are moved. The seat parts are fixed. - Click Close twice.
Create the Interface between Dummy Feet and Floor
Creation of an interface between dummy feet and the floor.
- Right-click in the Contact list and select Create New > Tied with void (Type 10).
- Set the dummy feet as secondary nodes.
Set the floor as main surface.
Figure 22. - Set the interface Title to Feet - Floor.
- Set Gap for impact activation to 3.0 mm.
- Click Save > Close.
Modify Seat Cushion Mesh
Modifying the seat cushion mesh to conform to the dummy using the Seat Deformer tool.
Edit the Pre-simulation Settings
![rd3150_presimulation](../../../images/solvers/rd3150_presimulation.png)
Figure 23.
Select the Seat Parts
Foams assembly, Seat plate,
Backseat plate, Seat frame,
and Backseat frame, as shown below.
Figure 24. -
Click Safety > Seat Deformer > Pre-simulation (new) and click Add selected parts of Tree
Figure 25.
Review the Results and Apply the Deformed Shape
Once the pre-simulation is completed, review the results in by opening the
.h3d file. Create a cut section in the middle of the
dummy and verify that the dummy does not intersect/penetrate the seat
foam.
Figure 26. - If an intersection/penetration does not exist, go back to the window and load the results by clicking Yes in the dialog.
When the job is completed, click Yes to load the
results.
You can also load the results by clicking File > Import > h3d node coordinates, then click Yes to the message Warning: all the nodes coordinates will be replaced by the ones found in the selected .h3d file.
Figure 27.
Figure 28.
Check Initial Penetration between Seat and Dummy
- Click LoadCase > Contact Interface to open the Contact Interface tab.
- Select interface Dummy - Seat.
). Penetrations exist between the seat beam and the dummy.
Click Select All (
Click Highlight by Vector (
Figure 29. -
Click Fixed part (
Click Fixed part (
) and then select the displayed parts of the dummy.
Only the nodes of the seat cushion are moved. The parts of the dummy are fixed. - Click Close.
Loadcase Setting
Update Initial Velocity
Update the initial velocity defined in the model to include all the nodes in the model.
- Click LoadCase > Initial Velocity to open the Initial Velocity tab.
- Select the initial velocity All in the list.
Click See selected initial velocity (
Right-click in the Support entry box and click Select in graphics > Add all nodes (
Change [Vx] X Velocity from -10000 to
-13000 mm/s.
Figure 30. - Click Save > Close.
Update Imposed Velocity
Update the imposed velocity on the floor to decelerate the car.
- Click LoadCase > Imposed > Imposed Velocity.
- Select Imposed velocity in the list.
Click See selected imposed velocity (
The floor rigid body is displayed on the screen. The imposed velocity is defined on its main node.
Figure 31. -
Right-click the Time Function entry box and select
Edit function. Check if the initial value of the
function is the same as the initial velocity.
Figure 32. - Click Save > Close.
Set Boundary Conditions
To simulate the Sled Test, you need to constrain all degrees of freedom on the floor except X-direction.
- Click LoadCase > Boundary Condition.
- Select Floor in the list.
Click See selected boundary condition (
The floor rigid body is displayed on the screen. The boundary condition is defined on its main node. -
Verify that the degree of freedom for Ty, Tz, Rx, Ry, and Rz are fixed.
Figure 33. - Click Save > Close.
Set Time History Data
Select Nodes
- Click Data History > Time History.
- Select the node group H350MEF2D00_th_nodes.
Click See selected th (
). These are the nodes of the dummy rigid bodies.
- For the first 5 nodes of the group:
- Select the node in the list.
Click See selected node (
- Enter a name in the field Node name, as shown in the table.
- Click Ok.
Figure 34. - When all labels are defined, click Save > Close.
Select Parts
Select the second and third part
group on the list.
Figure 35. -
Click Delete selected th (
Click Yes to the question in the main window.
The selected parts groups are deleted from the model.
- Select the remaining part group in the list.
the root of the
tree.
Figure 36. -
Switch back to the Data History panel and click Add parts by tree
selection.
Figure 37. - Click Save.
Add Interfaces
- Select all interfaces in the list.
Right-click and select Data History > Yes.
Figure 38.
Clean the Model
- Go to Quality Module.
- Select Check All Solver Contact Interfaces.
- Make sure there are no intersections and initial penetrations; if so, fix them.
- Click Close.
- Go to Mesh Editing and clean so that all the unused materials and properties are removed.
Create Control Cards and Export Model
Click Model > Control Cards to create the Control Cards in the images below.
Note: The /DT/SHELL/DEL command is used to delete some of the rigid body shells to allow the dummy’s joints to bend during the simulation.
Figure 39.
Figure 40.
Figure 41.
Figure 42. -
Click File > Export > Radioss.
Figure 43. -
Enter a name for the model in the file output window and click
OK.
Figure 44. - Write relevant information regarding your model in the Header window.
Click Save Model.
The model is now ready to be computed.
