Starter Subroutine LECRnn
This subroutine reads user failure model input data. The number of specific failure model cards and their formats are free.
Arguments
C----------------------------------------------------------------------------
SUBROUTINE LECRnn (IIN ,IOUT ,UPARAM ,MAXUPARAM,NUPARAM, NUVAR,IFUNC,MAXFUNC,NFUNC)
| Argument | Format | Description |
| IIN | Integer read only scalar | Input file unit (ROOT_nnn0.rad) on which the data are read. |
| IOUT | Integer read only format | Output file unit (ROOT_nnn0.out). |
| UPARAM | Float array | Array with a size NUPARAM used to store failure material data. |
| MAXUPARAM | Integer read only scalar | Maximum possible size of UPARAM. |
| NUPARAM | Integer scalar | Effective size of UPARAM. (MAXUPARAM, NUPARAM, MAXUPARAM are set to 1000). |
| NUVAR | Integer scalar | Number of extra variables needed for each integration point of each elements. |
| IFUNC | Integer array | Array with a size of NFUNC containing the list of Radioss functions used in failure model. The function numbers are stored in this array (not in UPARAM) due to a possible renumbering of the function’s numbers. |
| MAXFUNC | Integer read only scalar | Maximum possible size of IFUNC. |
| NFUNC | Integer scalar | Number of Radioss functions. |
