Objectives
Objectives are metrics to be minimized or maximized in an optimization exploration. Common examples are minimizing displacement to find the stiffest design for a system or minimizing mass to find a lightweight design.
Create Objectives
Create optimization objectives from existing responses.
Objectives can only be applied to an Optimization exploration.
| Method | Steps | Notes |
| (A) Use the microdialog of an existing response |
| (B) Use the Responses tab in the Design Explorer |
| (C) Use the Goals tab in the Design Explorer |
To rename the objective, double-click the corresponding
Name field. To apply/unapply an objective to the Active Exploration, turn on/off the corresponding Active check box. |
