Create a Reference Axis
Reference planes can be used with the Sketch, Slice, and Mirror tools to create or modify geometry, or to create section cuts.
Discover new features and enhancements.
New to Inspire? Learn the basics here.
Start using Inspire with our interactive tutorials.
Create parametric sketches, geometry, and PolyNURBS with construction history and variables.
View and edit the construction history of your model.
Create and assign variables to parameters when modeling.
Global references are the global origin, axes, and planes shown in the modeling window. They can be helpful when creating and defining your model.
Create and modify parametric surfaces and solids.
Create and modify reference planes, axes, or points.
Extrude profiles or 2D surfaces in one or two directions to create solids or 3D surfaces with optional end caps. Create a new part or combine, merge, subtract, or intersect the extruded shape with existing parts.
Revolve one or more faces, sketches, lines, or 2D edges about an axis.
Push, pull, or revolve a face, sketch, line, or 2D edge to extrude it into a solid or surface, create or resize a hole, eliminate rounds, or modify wall thickness.
Create a pipe along one or more edges/lines. The pipe has a uniform cross section that can be circular, square, rectangular, or triangular.
Mirror parts across a symmetry plane.
Create a linear or circular pattern of parts or faces.
Extract selected geometry features and transfer them to a new part.
Add draft to one or more faces of a part.
Use the Patch tool to fill in missing surfaces, or to remove and remake bad or problematic surfaces.
Create a new part by using one set of solids to edit another set of solids.
Slice a set of solid objects with a cutting plane or surfaces.
Project tools onto targets in a specified direction and split the targets. You can also extract the projection without splitting the targets to create wire geometry.
Clean up problem areas in the geometry of a model before running an analysis.
Divide a solid part into design and non-design regions by selecting a hole, pocket, or face to offset.
Create fillets or chamfers along an edge.
Remove material and create thin walls to generate a shelled part.
Offset surfaces or parts, thicken surface parts and convert them to solids, or thicken and hollow solid parts.
Retain only the intersecting portions of one or more parts.
Translate, rotate, copy, or extend features.
Resize parts in your model, which is useful when working with an imported model that is associated with a different default unit system.
Extract a midsurface or side faces from thin solids, and determine where surfaces are represented.
A part instance creates a copy of the part that is linked to the original part. When the original part is updated, the instance is automatically updated as well.
Replace a part in your model with an alternative design.
Create polymesh objects from other types of geometry and results.
Create free-form solid geometry that is smooth and continuous.
Set up your model and run a structural analysis or optimization.
Set up and run a motion analysis, plot the results, and export the results.
Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method.
Set up and run a basic porosity or thinning analysis.
Preapare and run an additive manufacturing simulation, and export a file for 3D printing.
Learn how to access the Inspire Python API including online help, quick start demos, and the Extension Manager.
View the glossary, frequently asked questions, and errors and alerts.
Learn keyboard shortcuts and mouse controls for common operations.
Previews for axes based on the selected option will appear as you move your cursor in the modelling window.
| Method | What to Select |
| Through Cylinder | Select a cylindrical face. |
| Through Two Points | Select two points. |
| Through Edge | Select a straight edge. |
| Through Two Planes | Select two non-parallel planes or planar faces. |
| Normal to Face at a Point | Select a planar face and a point. |
on the guide bar or microdialog.
The axis is created in the modeling area and is also available in the Model Browser’s References directory.
(c) Altair Engineering, Inc. All rights reserved.
