Select Variables
Variables are the columns of data used by visualizations. For example, if you have a database of sales information broken down by product, you might associate the total amount of sales for a given with the Size variable in a Treemap. You could also associate the difference between this year’s sales and last year’s sales to the Color variable for the same Treemap. This simple configuration will let you see at a glance which products are bringing in the most revenue and which products are increasing and decreasing in sales.
Each visualization uses a different set of variables, depending on the capabilities of the visualization:
Snapshot Visualizations
Visualization |
Variables |
Bar Graph – Vertical |
Bar Graph - Horizontal |
Box Plot |
Bullet Graph - Vertical |
Bullet Graph - Horizontal |
Categorical Line Graph |
Circle Pack |
Donut Chart |
Donut Gauge |
Dot Plot – Vertical |
Dot Plot – Horizontal |
Funnel Chart |
Heat Matrix |
Map Plot |
Network Graph |
Numeric Line Graph |
Numeric Line Graph – Vertical |
Numeric Needle Graph |
Numeric Needle Graph – Horizontal |
Numeric Stacked Needles |
Numeric Stacked Needles – Horizontal |
Pareto Chart |
Pie Chart |
Record |
Scatter Plot |
Scatter Plot 3D |
Shapes |
Surface Plot |
Surface Plot 3D |
Table |
Ticker Tile |
Treemap |
Waterfall Chart |
