Library Path Management
If the interface from ECAD library is not available, register the library path manually.
Search library paths.
You can search the library paths with some of the information in
library as a keyword.
- TEST* (Search for strings starting with TEST)
- *TEST* (Search for strings containing TEST)
- *TEST (Search string ending with TEST)
Click Edit and select Add to add
a new library path.
Figure 1. -
Click Edit and select Delete to
delete the selected library path.
If there is a library on the path, it cannot be deleted.
Edit Library Path.
Click a library path to open the edit library path information page and
the library manager can edit information.
