Check messages from systems such as the results of requests and other requests for your approval, change information
of part use, change your designation as the person in charge of the development process, and check the KPIs for the
status in Parts Registrations and Design Revisions.
Show progress and history of all stages from creating to completing.
Search filter by each stage: You can select item want to display below.
Design History: Displays history of stages filtered by the upper search
filter. Figure 1.
Select an item in the search column to display the process
history. Figure 2.
Click
Show all to see all information.
