If
OpenMatrix language supports conditional execution of statements using the if/elseif/else construct.
if condition1
  block1
elseif condition2
  block2
elseif conditionN
  blockN
else
  blockElse
end
      Each condition is an expression. If the expression evaluates to a non-zero (for example, true) value, the code in that block is executed. The conditions are tested in order. At most, one block is executed for each set of if statements. The elseif and else statements are optional. The blockElse is run only if no other blocks were run.
Example 1
x= 4
     if x == 4
           disp('hello 4')
     end
      Example 2
x= 5
if x == 4
      disp('hello 4')
elseif x == 5
      disp('hello 5')
end
      Example 3
x= 3
if x == 4
      disp('hello 4')
else
      disp('hello number')
end
      Example 4
x= 3
if x == 4
      disp('hello 4')
elseif x == 5
      disp('hello 5')
else
end
