Flow Simulator is an integrated flow, heat transfer, and combustion design software that enables multidisciplinary
engineering simulations to optimize machine design
The Labyrinth Seal Tooth by Tooth (TbT) element is typically used to model leakage
flow through labyrinth seals found in rotating machinery (gas turbines). The flow
rate, swirl, and fluid temperature rise due to windage are calculated based on the
seal geometry, and fluid conditions at the inlet and exit of the seal.
The main feature of this element is that it performs a tooth by tooth marching along
the flow direction to calculate the Pressure distribution inside the seal. It also
takes into account local (in-pocket) changes in fluid properties due to changes in
pressure and temperature, thus providing a more detailed modelling of the labyrinth
seals.
The seal clearance is the main dimension that controls the flowrate passing through
the seal. It is the distance between the tip of the seal tooth and the opposite
surface which is usually honeycomb. The seal clearance changes during gas turbine
operation since the parts move due to temperature and rotation. With labyrinth seal
TbT element, users can input individual seal clearances for every tooth in the seal
and study their impact on leakage.
The element is typically used for compressible flow, but Flow Simulator can use this
element with incompressible or compressible fluid.
Create a Lab Seal TbT in the GUI
The Lab Seal Tooth by Tooth element is located in the Compressible Gas
Elements - Seals section. Figure 1.
The figure below shows the geometric inputs. The seal clearance and seal geometry are
the major inputs. Besides this, you must enter honeycomb information. Figure 2.
A labyrinth seal typically has the seal teeth rotating. This requires you to enter an
RPM reference condition in the Solution Panel. Figure 3.
Labyrinth TbT Seal Inputs
Below is a table of the inputs for the labyrinth TbT seal. See the image in the user
interface to understand the geometric variables.
Labyrinth Seal TbT Element Input
Variables
Index
UIName (.flo label)
Seal Clearance (CL)
Seal clearance (Can be averaged or tooth by tooth)
2
Nominal Seal Radius
Or Inlet Radius
(RAD)
Nominal seal radius for a straight seal or the inlet radius for a
stepped seal.
3
Number of Teeth (NT)
Number of teeth in seal.
4
Seal Axial Pitch (PT)
Seal axial pitch.
5
Tooth Tip Width (WT)
Axial width of seal tooth tip.
6
Seal Tooth Height (HT)
Seal tooth height.
This variable influence only the windage calculated for a
rotating seal.
7
Wedge Angle (AN)
Angle between sides of a seal tooth.
8
Rotor Surf. Rot. Speed (RPMSELR)
Rotational speed pointer of seal rotor surface. 0.0: Specifies a
stationary element.
1.0:Points to general data ELERPM(1). 2.0: Points to general data
ELERPM(2). 3.0: Points to general data ELERPM(3).
Index
UIName (.flo label)
Slant Angle (SL)
Angle the tooth centerline makes with the radial
direction.
Positive angle if tooth is angled into the flow and
negative angle if slanted away from the flow.
10
Land Surf. Rot. Speed (RPMSELL)
Rotational speed pointer of seal land surface. 0.0: Specifies a
stationary element.
Points to general data ELERPM(2). 3.0: Points to general data
ELERPM(3).
11
BASE_EQUATION
BASE EQUATION is the user dependent choice for pressure
calculation formula in tooth by tooth marching:
0:
Saikishan-Morrison Base Equation
1: Neumann Base
Equation
2: Compressible Flow Function
The details
of these base equations are provided in the Theory
Section.
12
Portion of Ustrm Cham. Dyn. Head Lost (DQ_IN)
Inlet dynamic head loss.
If DQIN ≥ 0 and the upstream chamber
has a positive component of relative velocity aligned with the
axis of the tube, the driving pressure will be reduced by the
equation:
The default value of -1.0 will be interpreted by
Flow Simulator as a flag to use only static pressure if the
upstream chamber is an inertial chamber and a DQ_IN of 0 if the
upstream chamber is a momentum chamber.
13
Element Alignment (AXIS_DIR)
Direction of positive flow through the seal
If AXIS_DIR ≥ 0,
the axial direction for positive flow is assumed to be the
direction defined by THETA = 0, PHI = 0.
If AXIS_DIR <
0, the axial direction for positive flow is assumed to be the
direction defined by THETA = 180, PHI = 0.
14
Laminar-Transitional Reynolds Number(RE_LAM)
Reynolds number below which pocket swirl flow is assumed to be
laminar. Flow at Reynolds numbers between RE_LAM and RE_TURB are
assumed to be in the transition region. Defaults to 2070 for
Labyrinth Seal.
15
Turbulent-Transitional Reynolds Number (RE_TURB)
Reynolds number above which pocket swirl flow is assumed to be
turbulent. Flow at Reynolds numbers between RE_LAM and RE_TURB are
assumed to be in the transition region. Defaults to 2530 for
Labyrinth Seal.
16
Clearance Factor Method
(KFAC_METHOD)
0: Bell-Bergelin curve for CD of annular orifice
1:
Bell-Bergelin Advanced, Table Lookup for multiple Re
(Default)
-1: User supplies their own KFAC, either
constant value or calculated using controllers. See KFAC details
below.
17
Kinetic Energy Carryover Method (KE_METHOD)
0: Vermes 1961 Kinetic Energy Carryover curve 1: Morrison Kinetic
2: Minimum of Vermes and Morrison curves
(Default, matches NASA Tipton data best)
3:
Saikishan-Morrison
4: Neumann KineticEnergy Carryover
curve
-1: User supplies their own KEMULT, either constant
value or calculated using controllers. See KEMULT details
below.
Index
UIName (.flo label)
Honeycomb Method (HC_METHOD)
1: Auto, Tipton/Schramm Method (Default) – Tipton for Straight
Seals, Schramm for Stepped Seals
2: Stocker curve for straight
seals
3: Schramm curve for stepped seals
4: Tipton
table lookup for straight seals.
own HCMULT, either constant value or calculated using
controllers. See HCMULT details below.
19
Slanted Teeth Method
(SL_METHOD)
1:Curve fitted to NASA Tipton data
-1:User supplies their own
SLMULT, either constant value or calculated using controllers.
See SLMULT details below.
20
Honeycomb Size (HCSIZE)
Honeycomb Size – Standard choices are 1/32”, 1/16”, and
1/8”.However, it is possible to input a custom honeycomb size.
Solver units are inches.
21
Clearance Factor(KFAC)
Clearance factor is the Discharge Coefficient of a single annular
orifice or tooth gap. The value is between 0 and 1, usually between
0.6 and
0.9. See Vermes 1961 or Bell-Bergelin.
22
Kinetic Energy Carryover Factor (KEMULT)
Kinetic Energy Carryover Factor is a value from 1 to about 2.4.
It accounts for axial momentum and energy that is retained as flow
goes around a tooth. A value of 1 means the tooth blocked all
kinetic energy. A value higher than 1 implies some kinetic energy
was carried over. Please see Vermes 1961, Morrison, and Alexiou for
details.
23
Honeycomb Flow Multiplier (HCMULT)
Honeycomb Flow Knockdown Factor is a multiplier that is applied
to non-honeycomb leakage flow to calculate the corrected leakage
flow with a honeycomb stator. Typical values are from 0.8 to 1.2.
Values less than one imply the honeycomb is supplying an additional
source of resistance, which is often true for straight seals. Values
greater than one imply that the honeycomb is creating a new path for
leakage flow, which is often true for stepped seals. Please see
Stocker and Schramm for additional details.
24
Slant Flow Multiplier (SLMULT)
Slanted Teeth Flow Knockdown Factor is a multiplier that is
applied to straight-tooth leakage flow to calculate the corrected
leakage flow with slanted teeth. Typical values are from 0.85 to
1.1. Three-dimension flows in seal pockets are complex, and it is
difficult to explain why the factor is sometimes less than one and
sometimes greater.
25
Swirl Carryover Factor per Tooth (ETATOOTH)
Swirl Carryover per Tooth is the fraction of tangential fluid
velocity(relative to the stator) that passes each tooth and enters
the next pocket. This is a calibration parameter that helps to match
the correct swirl and windage heating. It is especially useful for
stepped honeycombseals where the air passes over the tooth and
immediately impinges on the honeycomb step.
Index
UIName (.flo label)
Friction and Windage
–Rotor:
Friction Relation
(FRIC_REL_R)
0: Swamee-Jain Approximation to Colebrook-White-Moody Friction
(Default)
1: MacGreehan-Ko Rotating Cavity/Pocket
Friction
5: Sultanian
-1: User supplies
FRICF_STATOR, either constant value or calculated using
controllers. See FRICF_STATOR details below.
27
Rotor Sandgrain Roughness (ROUGH_ROTOR)
Roughness of the rotor surface. It is assumed to be a sand-grain
type roughness, which is consistent with
Colebrook-White-Moody.
28
–Rotor:
Friction Multiplier(F_MULT_ROTOR)
Friction multiplier on Rotor is used if you want the friction
curve to follow that same basic trend as Swamee-Jain or
MacGreehan-Ko but your custom friction curve differs by a
multiplication factor.
29
–Rotor:
Friction Coefficient
(FRICF_ROTOR)
Fanning Friction Coefficient on Rotor can be supplied as a
constant value, or it can be calculated using a controller.
30
–Rotor:
Total RotorSurface Area
(ASR)
Generally, ASR=0 and the rotor friction area is calculated from
other geometric inputs such as tooth height, spacing, wedge angle,
slant angle, etc. If you enter a non-zero value, your input will
override the calculated area. Solver units are sq. in.
31
Frictionand Windage
–Stator:
FrictionRelation
(FRIC_REL_S)
(Default)
1: MacGreehan-Ko Rotating Cavity/Pocket Friction
5: Sultanian
-1: User supplies FRICF_STATOR, either constant value or
calculated using controllers. See FRICF_STATOR details
below.
32
Stator Sandgrain Roughness (ROUGH_STATOR)
Roughness of the stator surface. It is assumed to be a sand-grain
type roughness, which is consistent with Colebrook-White-Moody.
Estimating a suitable roughness for a honeycomb surface is one
challenge, but no advice can be given here.
33
–Stator:
Friction
Multiplier(F_MULT_STATOR)
Friction multiplier on Stator is used if you want the friction
Index
UIName (.flo label)
–Stator:
(FRICF_STATOR)
Fanning Friction Coefficient on Stator can be supplied as a
35
Frictionand Windage
–Stator:
Total Land Surface Area
(ASS)
override the calculated area. This is especially useful for stepped
seals, since the current lab Seal element does not have a step
height input. However, it could be better to ignore the step height
and rely on ETATOOTH – please see above. Solver units are sq.
in.
36
(CL_TABLE)
Number of entries in the CL_VALUES table.
37
Groove Depth(GRV_DEPTH)
Depth of the groove (GD) in the honeycomb (or other land
material)
38
Groove Width(GRV_WIDTH)
Width of the groove (GW) in the honeycomb (or other land
material)
39
Groove Tooth Axial Position
(GRV_AX)
Location of the tooth in the groove. 0 = tooth in the center of
the groove
-1 = tooth hitting left edge of groove1 = tooth hitting
right edge of groove
Not used in built-in methods yet but
can be useful for controller or custom groove loss
correlations.
40
Groove Multiplier (GRV_MULT)
Groove Flow Knockdown Factor is a multiplier that is applied to a
no-groove leakage flow to calculate the leakage flow with a groove.
Can be greater or less than 1. If the tooth is outside the groove,
GRV_MULT should be > 1 indicating more flow through the
seal.
41
Groove Method(GRV_METHOD)
Method to use to calculate the groove effect.
-1= User
Specified GRV_MULT 1 = Zimmerman Method
42
User Multiplier (USRMULT)
A user supplied flow knockdown factor. Can be used with a
controller for general purpose effects if needed.
Index
UIName (.flo label)
Exit Radius
(RAD_EX)
The exit radius for a stepped seal.
44
Pocket Heat Transfer Option – Rotor
(HTOPT_ROTOR)
The heat transfer option to use on the rotor surface in each
pocket.
0: No Heat Transfer (default)
1: Heat Transfer
ON with a constant HTC
2: Heat Transfer ON with a constant
Q
>1000: Heat Transfer ON with a custom HTC correlation
(ROTATING_CAVITY_NU)
45
Pocket Heat Transfer Option – Stator
(HTOPT_STATOR)
The heat transfer option to use on the stator surface in each
pocket. Same options as rotor surface of pocket.
Table1
Individual Tooth Clearances(CL_VALUES)
There is an option to provide an array of individual clearance
values, one for each seal tooth. The method uses a curve that is
fitted to Tisarev, Falaleev, Vinogradov 2014 data, and computes an
effective tooth clearance from the array of individual tooth
clearance values. Solver units are inches.
The following equation
is used to calculate and effective clearance for the entire
seal.
HTC or Q Tables
(ROTOR_PKT_HTC_OR_Q), (STATOR_PKT_HTC_OR_Q)
A constant Heat Transfer Coefficient (HTC), BTU/(hr ft^2 F) or
constant heat addition (Btu/sec).
Separate tables for Rotor and
Stator. One entry for each pocket.
The table only exists
when needed for the heat transfer option. No table if there is
no heat transfer.
Wall Temperature Tables
(ROTOR_PKT_TWALL), (STATOR_PKT TWALL)
The wall temperature to us pocket heat transfer (deg
F).
Separate tables for Rotor and Stator. One entry for each
pocket.
The table only exists when needed for the heat
transfer option. No table if there is no heat
transfer.
Labyrinth Seal TbT Element Theory
Flow Rate Calculation Base Equations:
Using Saikishan Morrison Base Equation:
The Saikishan Morrison equation
(Ref 2) for calculation of flow rate across the nth tooth is
defined as:(1)
Where:
= mass flow rate across the
nth tooth
= Discharge coefficient across the
nth tooth
= Geometrical Flow area through the
clearance
= Expansion factor accounting for fluid
expansion after coming out of tooth gap
= Density of fluid at the upstream
pocket of tooth
= Pressure at upstream pocket of
tooth
= Pressure at downstream pocket of
tooth
is the geometrical flow area:
The
expansion factor as per Saikishan Morrison is given as:(2)
For compressible flow:(3)
For incompressible flow:(4)
The discharge coefficient for , the nth tooth is written
as:(5)
These factors are described in the section ‘Leakage
Flow factors’ below.
Using Neumann Base Equation:
The Neumann Base equation (Ref 10) for
calculation of flow rate across the nth tooth is defined
as:(6)
Where:
nth tooth
nth tooth
clearance
= Temperature of fluid at the upstream
pocket of the tooth
= Gas constant of fluid at the upstream
pocket of tooth
tooth
tooth
Using Compressible Flow Function:
The Compressible flow function for the
as:(7)
Where:
is the total flow parameter,
and:(8)
(9)
Where:
= Temperature of fluid at the upstream pocket of the
tooth
= Discharge coefficient across the nth
tooth
= Geometrical Flow area through the clearance
= Gas constant of fluid at the upstream pocket of
tooth
= Specific heat ratio of fluid at the upstream
pocket of tooth
= Total Pressure at upstream pocket of tooth
= Gravitational constant
Leakage Flow Factors
KEMULT
KEMULT is the Kinetic energy carryover factor. There are six options for the kinetic
energy carryover.
Vermes.
Morrison (Ref 2, eq 5)
Vermes-Morrison.
Use the minimum alpha from 1 and 2
User-specified KEMULT.
SAIKISHAN_MORRISON (Ref 2, eq 7).
This method uses the flow Re to
calculate the KEMULT. Since the flow Re depends on the flow through the
seal, this method will use the flow from the previous iteration.
Neumann (Ref 10)
KFAC
KFAC, or clearance factor, is equivalent to the Vermes K variable that accounts for
the effect of the ratio of seal tooth tip width to seal clearance. There are two
options:
The value used approximates the data shown in Figure 2 of Vermes paper (also
from Bell-Bergelin paper, ref. 3) and is given by the equation:
User-specified.
Bell-Bergelin Advanced. Uses a table of KFAC vs WT/CL for several Reynolds
numbers from ref. 3. Bilinear interpolation used to find KFAC. The
Bell-Bergelin equation shown above matches the Re=10,000 curve. The Advanced
option is more accurate for Re<10,000. Re is the annular orifice (tooth
gap) Reynolds number and can be found in the *.res
file. Figure 4.
Saikishan Morrison KFAC
It uses the Clearance factor from Saikishan
Morrison paper (Ref 2). The factor described as the CD for first tooth
is treated as KFAC here. Since Saikishan Morrison formulation correspond
for straight and smooth seals, the CD for first tooth has only two
components KEMULT and KFAC. While KEMULT = 1.0 for the first tooth. So,
as per Saikishan Morrison, the KFAC is written as:
For first
tooth:(10)
For subsequent teeth:(11)
Neumann KFAC
Neumann KFAC is the clearance factor as described in the Ref
10. It takes into account the pressure ratio at upstream and downstream
of the tooth. Neumann KFAC is given by following
equation:(12)
(13)
Where:
is the specific heat ratio at the
upstream pockets.
SLMULT
HCMULT
The honeycomb flow multiplier has five options.
Auto method uses Tipton table for straight seals and Schramm equation for
stepped seals. This is the default.
Schramm Stepped Seal (Ref 4, Fig 12).
(14)
Stocker Straight (Ref 4, Fig 12).
(15)
Tipton Straight (Ref 7, Fig 26).
An HCMULT is calculated using bilinear
interpolation of the curves shown here. Figure 5.
User-specified.
GVRMULT
The flow knockdown factor due to a groove in the honeycomb.
There are two options:
-1: User-supplied.
1: Based on Zimmerman (Fig. 7 in Ref 8).
Figure 6.
The groove width/groove depth (GW/GD) is limited in the solver to
between 1 and 10. The (groove depth + clearance)/clearance ((GD+CL)/CL)
is limited in the solver to between 1 and 3. Valid for Re>5000,
GW/GD>2.5, but correlation uses GW/GD=1 curve also.
Choked Flow Calculation
For compressible gases the calculated seal mass flow is compared to the mass flow for
choked flow through the last tooth. If the choked flow through the last tooth is
less than the calculated seal mass flow, the choked flow is used. The equations for
the choked flow calculation are:(16)
(17)
Where:
This account for the additional flow area if the honeycomb cell allows the seal to
flow more than a smooth surface (HCMULT>1 if clearance is small and HC size is
large).
Calculationof Seal Pocket Pressure:
Using Saikishan Morrison Base Equation, rearranging Eq.
1:
(18)
Using Neumann Base Equation, rearranging Eq. 2:
(19)
For Compressible flow function, the mass
flow rate across the first tooth is utilized to calculate the pressure
ratio across the subsequent teeth (Using Eq. 3). At the last teeth,
however the pressure ratio is known after the tooth by tooth marching is
complete for that iteration, therefore the pressure ratio is used in
Eq.3 and the mass flow across last tooth is determined. At convergence,
the relative difference between mass flow across the first tooth and
last tooth becomes smaller and smaller.
Figure 7. Tooth by Tooth Marching Algorithm
Calculation of Seal Pocket Swirl
The seal “rotor” surface area is calculated using the following: Figure 8.
Surface area per pocket:
Where:
Surface area for all pockets:
The labyrinth seal “stator” surface area is calculated using the
following:(20)
Where:
Sultanian Friction (ref 9)
Rotor Surface:
Stator Surface:
Calculation of Seal Windage Temperature Rise
Seal Pocket Heat Transfer
In addition to the fluid temperature change due to windage, the fluid temperature can
also change due to the fluid convection to the pocket surface. The convection Q is
applied at each pocket. The typical convection heat transfer equation is
used:(21)
HTC = heat transfer coefficient supplied by the user or calculated by the
correlation
Area = pocket surface area
Tsurf = the surface temperature supplied by the user
Tfluid rel = the relative fluid total temperature, adjusted for
fluid and surface rotation
Labyrinth Seal TbT Element Outputs
Outputs in the file with an *.res extension. Output units
controlled by user settings in the “Output Control” panel. Figure 9.
Name
Units ENG,SI
SEAL_POSITIVE_FLOW_DIRECTION
Direction of positive flow through the seal.
1: Axial direction
for positive flow is assumed to be the direction defined by
THETA = 0, PHI = 0.
-1: Axial direction for positive flow
is assumed to be the direction defined by THETA = 180, PHI =
0.
None
Name
Units ENG,SI
PRESSURE
Static pressure in every pocket in the seal is output in the form
of a table in a *.res file.
Psi, MPa
TEMPERATURE
Total temperature in every pocket in the seal is output in the
form of a table in a *.resfile.
0F, K
RHO
Density in every pocket in the seal is output in the form of a
lbm/ft3, kg/m3
TOOTH
Seal tooth type (STRAIGHT or SLANT).
None
CL
Seal clearance for every tooth is provided in the form of a table
in a *.res file.
Inch,mm
AREA
Seal geometric flow area for every tooth is provided in the form
Inch2, mm2
RAD
Nominal seal radius. Distance from engine centerline to the seal
tooth tip.
Inch,m
WT
Inch,mm
PT
Seal axial pitch.
Inch,mm
NO_TEETH
Number of seal teeth.
(number)
HT
Seal tooth height.
This variable influences only the windage
calculated for a rotating seal.
Inch,mm
K/E_RPM
Rotational speed of the rotor surface.
rev/min
LAND_RPM
Rotational speed of the land surface. Also referred to as
“stator”.
rev/min
DT
Absolute total temperature rise across the seal.
degF,k
TEX
Absolute total temperature at the exit of the seal.
degF,k
XKABS_IN
Swirl ratio entering the seal. Swirl in the absolute frame of
reference.
None
XKABS_OUT
Swirl ratio exiting the seal. Swirl in the absolute frame of
reference.
None
ASR_TOTAL
Rotor surface area.
In^2,m^2
ASS_TOTAL
Stator(aka Land) surface area.
In^2,m^2
DH_POCKET
Hydraulic diameter of the seal pockets. Assume each pocket is
same.
Inch,mm
KFAC
Calculated clearance factor.
None
KEMULT
Calculated kinetic energy carryover factor.
None
HCMULT
Calculated Honeycomb Flow knockdown factor.
None
SLMULT
Calculated slanted tooth flow knockdown factor.
None
Name
Units ENG,SI
Expansion Factor
Expansion factor across every tooth for compressible
flows.
XKrel
Swirl ratio in each pocket. Swirl relative to the land, which is
usually stationary. If the land is stationary XKrel is in the
absolute frame of reference.
None
WIND.
Windage in each pocket.
BTU/s,W
ReynR
Reynolds number relative to the rotor surface.
None
FricFannR
Fanning Friction factor on the rotor surface.
None
ReynS
Reynolds number relative to the stator surface.
None
FricFannS
Fanning Friction factor on the stator surface.
None
MACH NO.
The Mach number of the flow in every tooth gap. Based on physical
area times HCMULT if greater than 1.0.
None
Re
Reynolds number of the flow in the tooth gap.
None
Labyrinth Seal TbT Validation
The labyrinth seal tooth by tooth results were compared to results from Tipton et.al.
(ref 7).
Total of 705 labyrinth seal cases using a wide range of geometries and operating
conditions.
Tooth Tip Radius (in): 2.0, 2.26, 3.0, 3.36, 5.0, 7.63
Clearances (in): .004, to .061
Geometry Ratios:
Pitch/Clearance: 4 to 156
Width/Clearance: .25 to 62.75
Width/Pitch: .031 to .67
Width/Honeycomb Size: .08 to .48
Clearance/Honeycomb Size: .04 to .65
Operating Conditions:
Pressure Ratio: 1.04 to 6.8
Rotor Speed (RPM): 0, 13000, 20000, 30000
Element Leakage flow factors Settings: Figure 10. Figure 11.
Statistics of the comparison based on:(22)
421 out of 705 test cases match within 10%.
Labyrinth Seal Tooth by Tooth References
Vermes, Geza, “A Fluid Mechanics Approach to the Labyrinth Seal Leakage
Problem,” Transactions of the ASME, Journal of Engineering for Power, April
1961, pp161-169.
Suryanarayanan, S & Morrison G.L “Labyrinth Seal Discharge Coefficient
for Rectangular Cavities”, ASME 2009.
K.J. Bell & O.P. Bergelin, "Flow Through Annular Orifices", ASME
1957.
Schramm V., Willenborg K., Kim S., Wittig S., “Influence of a Honeycomb
Facing on the Flow Through a Stepped Labyrinth Seal” ASME 2002.
Stocker,H. L., 1978, ‘‘Determining and Improving Labyrinth Seal Performance
in Current and Advanced High Performance Gas Turbines,’’ AGARD CP273.
McGreehan W.F., & Ko S.H.,1989, “Power Dissipation in Smooth and
Honeycomb Labyrinth Seals” ASME Paper No 89-FT-220.
Tipton D.L., Scott T.E, Vogel R.E., 1986, “Labyrinth Seal Analysis. Volume
3. Analytical and Experimental Development of a Design Model for Labyrinth
Seals” AFWAL-TR-85-2103.
Zimmermann H., Wolff K. H., “Air System Correlations Part 1: Labyrinth
Seals” ASME 98-GT-206.
Bijay K. Sultanian, “Gas Turbines – Internal Flow Systems Modeling”,
Cambridge Aerospace series, 2018, ISBN 978-1-107-17009-4.
Eldin, A. M. G., “Leakage and Rotordynamic Effects of Pocket Damper Seals
and See-Through Labyrinth Seals”, Texas A&M Dissertation, 2007.
