Linear approximation * exponential function of T
Presentation
This model defines a B(H) behavior law:
  • linear (without taking the saturation into consideration)
  • for an isotropic material
  • through a relative permeability μr which decreases in an exponential way when the temperature increases
It can be used for low magnetic fields as long as saturation is not reached.
Mathematical model
This model is a straight line whose μr slope varies with the temperature.
The corresponding mathematical formula is written:
B(H,T)= μ0H+ μ0( μr0 - 1)H.COEF(T)
where:
  • μ0 is the permeability of vacuum; μ0 = 4 π 10-7 [H/m]
  • μr0 is the relative permeability of the material for T = 0°C
  • COEF(T) is the previously described temperature coefficient
The shape of B(H) curve is presented in the figure below.
