Flux-Activate co-simulation: about
Introduction
Flux offers a coupling with Activate, compatible with Flux 2D and with Flux 3D. This coupling is available for all transient applications.
Implementation
Process tu run a co-simulation between Flux and Activate :
  • Preparation of the Flux project :
    • Standard description: geometry, mesh and physics
    • Specific description: creation of input and output parameters necessary to the coupling
  • Generation of component of the Flux – Activate coupling
  • Preparation of Activate model: :
    • Set the Flux access path in the preferences in Activate
    • Add a co-simulation block from the palette browser.
  • Configuration of the simulation parameters
  • Running the co-simulation
  • Post processing of results
Examples
Some examples are available starting from the supervisor, in the Open Example context.
