Export of N dimensions data table
Introduction
A data table allows regrouping, in the same file (.oml, .txt or .csv). Data values contained in parameters (geometric or I/O parameters) and sensors after a parametric or transient solving.
The goal may be analyzing or reusing the data in another software.
Steps to export data tables
- Launch the command through
 - Select the output parameters / sensors
 - Select the file format (.oml / .txt / .csv) and the file name
(For .oml files, enter the name of the files folder of destination. Each file contains one output parameter data)
 - The option Operation on a parameter intervalmay be enabled, it allows the
                  user to do a mathematical operation on the output parameter over a variating
                  parameter (time, angular or linear position, etc..):
- Select the parameter (time, angular or linear position, etc..) to apply the operation
 - Select the type of operation:
- RMS value;
 - Maximum value;
 - Minimum value;
 - Statistical average value;
 - Integral average value.
