OML file format for Activate / Compose (LookUp Tables ND)
Introduction
From version 2020 onwards, Altair FluxTM can export simulation results as an OML file that may be used in Altair ActivateTM to create a Lookup Table ND. Assimilable to model reduction, this export can replace time-consuming Finite Elements co-simulation while keeping a very high level of accuracy.
This feature is available for all applications in the 2D, Skew, and 3D modules of Flux. However, to generate this export, a parametrized scenario must be solved beforehand. Once integrated into a system application, the component allows the simulation software to take the Finite Element model into account by performing interpolations of the input and output values when requested.*
This export may also be used in Compose to apply a specific post-processing to the exported quantities (sensors, formulas and I/O parameters) in this file.
How to export an .OML file format for Activate / Compose (LookUp Tables ND)?
- in the menu Data Exchange, click on Export a data table;
 - choose the Outputs of the .oml file among the Input/Output parameters and the sensors;
 - select the format : .OML file format for Activate / Compose (LookUp Tables ND);
 - choose a Path to a folder where Flux will create the file;
 - select the Inputs of the file in the parameter list;
 - choose the type of value to export. To get all values, choose Current values.
How to use the exported OML file in Activate?
- put the .oml files in the same directory of the Activate project;
 - in the menu Diagram Home, chose the Context tab;
 - provide the name of the files created by Flux;Note: For example, if Flux exported the file TORQUE.oml, then only TORQUE should be written in Diagram Home (only one name per line).
 - verify in the menu Available variables of the Diagram Home if the variables were loaded correctly;
 - assign the variables to the LookUp Tables ND component.Note: The variable names (both inputs and outputs) are the same as in Flux.
How to use the exported OML file in Compose?
- open this OML file with Compose;
 - all the formulas, sensors and I/O parameters are now available in Compose defined as vectors.
