Compatibility of components according to the application
Compatibility component/application
The table below presents the compatibilities between components and the applications implemented with the Flux software:
Component | Magneto static | Steady Stat AC Magnetic | Magnetic transient | Magneto thermal | |||||
Flux2D | Flux3D | Flux2D | Flux3D | Flux2D | Flux3D | Flux2D | Flux3D | ||
Resistor | X | X | X | X | X | X | |||
Inductance | X | X | X | X | X | X | |||
Capacitor | X | X | X | X | X | X | |||
Source of voltage | Sinusoidal voltage source | X | X | X | X | ||||
Voltage source to be defined | X | X | |||||||
Source of current | Sinusoidal current source | X | X | X | X | ||||
Current source to be defined | X | X | |||||||
Coil conductor current | X | X | X | X | X | X | X | X | |
Coil conductor circuit | X | X | X | X | X | X | |||
Solid conductor 2 terminals | X | X | X | X | X | X | |||
Solid conductor N terminals | X | X | X | ||||||
Switch ron roff | X | X | |||||||
Diode | Diode_uc_i_ron_roff | X | X | ||||||
Diode_uc_i_exp_vf0_rb | X | X | |||||||
Diode_uc_i_exponential | X | X | |||||||
Brush-segment | X | X | |||||||
Squirrel-cage | X | X | X | X | X | X | |||
Ground | X | X | X | X | X | X |
