Manipulation of the electric circuit components in the standard context
Selection mode
The selection modes are presented in the table below.
A component of a circuit… | Is selectable … |
imported |
Select and Edit a component starting from the data tree
To select and then edit a component of the electric circuit starting from the Data tree:
Step | Action |
1 |
Select the component in the Data tree:
→ | The component is highlighted |
2 |
Edit the component in the Data tree:
or
The dialogue box corresponding to the component is opened The user can characterize or modify the circuit component |
Select and edit a component in the graphic zone CircuitView
To select a component of the electric circuit starting from the graphic zone available on the CircuitView tab:
Step | Action |
1 |
Select a component of the circuit:
2 |
Edit the circuit component:
or
→ | The dialogue box corresponding the component is opened |
Modifying/ characterizing an electric circuit component
To modify or characterize a component of the electric circuit under the editor (name, comment, model, terminals*):
Step | Action |
1 | Select the desired component |
2 | Edit the component or Edit array |
3 |
Modify the information in the dialogue box:
4 |
Validate the information:
→ | The component is characterized/modified |
Delete a component in the Data tree
To delete a component starting from the Data tree:
Step | Action |
1 | Select the component to delete |
2 |
Activate the command:
→ | A confirmation box is opened |
3 |
Confirm the deletion:
→ | The component is deleted |
