Mechanical analysis context: about
Environment
Necessary condition
The context is accessible under the following conditions :
- Project defined as magnetic application (transient, steady state, steady state AC)
- If the project is in magnetic transient, the solving scenario should not contain geometric parameter.
Valid domains
This context is accessible for the following Flux models :
- 2D plan
- Skewed
- 3D
Main steps
In the table below the main steps to generate a file of forces are described.
| Step | Action |
| 1 | Create the computation support |
| 2 | Compute forces |
| 3 | Check result by displaying arrows |
| 4 | Export forces |
Support and forces computation
As presented in the introduction, three computation methods exist. So there are three support types associated to the computation methods:
| Computation | Computation of surface magnetic forces on Flux mesh | Computation of surface magnetic forces on rotating machine imported mesh | Computation of volume Laplace forces on Flux mesh |
| Corresponding support | Support for magnetic surface forces computation | Support defined by an imported mesh from rotating machine | Support for Laplace volume forces computation |
