Data exchange: multiphysics spatial quantity
On the supports of exchange
The exchanged data are physical quantities such as the density of power losses, the temperature...
These quantities are known as local or spatial (defined in space) quantities. The name of these quantities is multiphysics spatial quantity.
Multiphysics spatial quantity: definition
A multiphysics spatial quantity is a Flux structure, which allows the storage of external spatial quantities in the Flux project.
These quantities are defined on a support of exchange of multipoint or nodes of mesh type.
Limitation
In the current version if the exchange support (of multipoint support type) does not coincide with a Flux region (volume, face or line region), the data importation will not be carried out on the entire support but on the part of the support pertaining to the region, chosen by the user.
