Results post-processing
Results post-processing: reminder
With a time dependent study and/or parametric analysis, the post-processing of results can be carried out:
- either by means of one of the solving process steps (selection of one solution)
 - or over a set of solving process steps (totality of solutions) by means of sensors
The post-processing over one solving process step (parametric case or computation time step) is presented in chapter Results post-processing: principles.
The post-processing over the totality of the solving process steps is presented below.
What can be done …
The sensors, the I/O parameters can be:
- evaluated for each solving process step (parametric case or computation time step)
 - represented graphically (2D curve) in function of other I/O parameters.
