Export of impedance model
Export files
In the Conductors Impedances application, the main result provided by PEEC computation is the impedance of the parts of the circuit defined by the user with the impedance probes. The user can export these equivalent characteristics and insert them into circuit simulators like SPICE, SABER, MODELICA, PORTUNUS, …
To achieve this, the user has to:
Step Action Result
1
Open one of the export dialog boxes:
  • either with the icons:
  • or with the menu bar: Post processing and then Results export
2
In the dialog box Export
  • click, on the right, on the icon to open the file manager
3
In the file manager:
  • Select the parent directory
  • Define the name of the directory where export files will be stored
  • Click Save
→ the name chosen for the directory appears in the export dialog box
4 Click on OK
A directory named:file_name.format *
is created and the export files are stored in it.
At each frequency step, some files are created; the prefix F# where # is the number of the step considered makes it possible to distinguish them.
The number and typology of the export files depends on the format chosen by the user, as detailed in the following table.
Note: * format represents the kind of export selected by the user; the different format possibilities are listed in the table below.
Format Fichiers
SPICE
F#_nom_repertoire.INFO
F#_nom_repertoire.CIR
SABER
F#_nom_repertoire.SIN
F#_nom_repertoire.AI_SYM
MODELICA
F#_nom_repertoire.MO
PORTUNUS
F#_nom_repertoire.I2P
IMPEDANCE F#_nom_repertoire.DAT
