Plotting an impedance curve
2D curves (evolution)
A 2D curve (evolution) is a curve representing a physical quantity according to the frequency. In the Conductors Impedances application the self and mutual impedances seen from the impedance probes are the only quantities available.
To create a 2D curve (evolution) the user has to:
Step Action Result
1
Open the dialog box 2D curve (evolution):
  • either with the icon:
  • or by the menu bar: Post processing and then Self or mutual impedance
2
Give a name to the 2D curve and select the two probes among which to plot the impedance.
If the same probe is selected in both boxes, a curve with the self impedance will be plotted; otherwise it will be a curve with mutual impedance
→ The 2D curves are displayed in a new specific sheet with the name of the physical quantity considered.
