Face: about
Faces
Faces can be built:
  • with the aid of automatic construction algorithm
    (automatic identification and creation)
  • by propagation from existing faces with the aid of a transformation
  • by extrusion from existing lines with the aid of a transformation
Faces built by Flux PEEC
The faces built by Flux PEEC are included in planar surfaces. The types of faces are presented in the table below:
Face of following type is built …
automatic
    (command Build Faces )
structured
  • by extrusion from lines (command Extrude lines
    with building option Add Faces, Lines and Points)
  • within the extrusion from faces (command Extrude faces
    with building option Add Volumes, Faces, Lines and Points)
  • by propagation of faces (command Propagate faces
Structured faces
The building of a structured face is shown in the figure below.
where :
  • bottom line is the source
  • upper line is the image
  • side lines are connection elements
