Flux Modeler: 3D building from to a 2D profile
Introduction
In the modeler, it is possible to build a 3D geometry starting from a 2D profile.
To build a 3D geometry from a 2D profile, it is necessary to create a 2D profile:
- In a plane specified by the user, we speak about a Sketch plane
 - Either directly from existing faces belonging to an object.
Then the built faces in this sketch or already existing and belonging to an object, can be extruded.
It exists 3 extrusion type:
- Extrusion along vector
 - Extrusion around axis
 - Helicoïdal extrusion
