Cleaning of mesh information
Cleaning of mesh
It is possible to clean the mesh data.
The mesh cleaning:
  • destroys all the assignment data (links between the mesh tools and the geometric entities associated with them)
  • preserves the mesh tools (mesh point, mesh line, mesh generator)
Interest
Cleaning is useful:
  • to remove all data locally adjustmented and to mesh only by aided mesh (for example)
  • to return to a starting situation (only geometric description, without any mesh information associated to the geometry)
Cleaning the mesh data
To clean the mesh data:
Stage Action
1
Activate the command:
  • in the Mesh menu, click on Clean all mesh data
    or in the Mesh toolbar, click on the icon
→ A warning box is opened.
2
Confirm the cleaning:
  • Click on Yes
→ The mesh tools are unassigned from all geometric entities.
Caution
  • Once this command is executed, the aided mesh box information are un-assigned from the geometry entities. It is necessary to "re-synchronize" the aided mesh box (open the box and click on OK / Apply) in order to retrieve these information.
  • Once this command is executed, linked and extrusive mesh generator that have been automatically created with geometric transformations are un-assigned.
