Deletion of the mesh
Mesh deletion
It is possible to switch from the geometry context to the mesh context. To modify a meshed geometry, it's necessary to first remove the mesh.
The mesh deletion:
- removes mesh elements (nodes, line, face and volume elements)
 - retains meshing tools (mesh point, mesh line, mesh generator)
Delete mesh
To delete the mesh:
| Step | Action |
| 1 |
                         Activate the command:
| → | A warning message box is open. |
| 2 |
                         Confirm the deletion:
| → | The mesh elements are removed. |
