Correction tools: Convert propagated entities
Introduction
The user may wish to « break » the links between entities, obtained by propagation.
A new function has been added allowing to convert the propagated entities into standard entities.
The command “Convert propagated entities” converts propagated entities into standard entities.
The user can then manipulate the converted entities independently from one another.
Access
This command is accessible in the menu Tools or by the contextual menu and is accessed by a right click on the graphic selection of entities.
Global / local Application
To apply this command, one must first make a graphic selection of the entities. The user can then apply this command on the assembly of the geometry. Selecting all or a part of the geometry (he selects only the desired entities).
