Refine a solution (continue / iterate)
Iterate on one step
The command Iterate on one step enable:
  • to “reprocess” one step incorrectly solved (because of non-convergence of the process)
  • to “reprocess” one step correctly solved but its result appears incorrect
    (first, it is necessary to improve the precision of the used iterative linear solver)
From the operation point of view, the command Iterate on one step enable to resume the iterative process, as presented in the table below.
Analysis without parameters
Application Scenario Continue
Non-transient
Mono-step
(a single step)
= Iterate on the step
Transient
Transient multi-step
(many steps "connected to each other")
= Iterate on the last step
Analysis with parameters
Non-transient
Parametric multi-step
(many independent steps)
= Iterate on the steps which has not converged
Transient
Transient and parametric multi-step
(many steps "connected to each other" or independent)
= Iterate on the last step which has not converged for one or several transient solving processes
