Post processing on a step (Selector of scenario / Selector of step)
Introduction
To carry out the results post-processing on a computation step, the user can select a scenario and/or a solving step. Then the user carry out the results post-processing on this step as in the case of a mono-step solving process.
Select a solving scenario / a computation step
To select a solving scenario and/or a computation step, follow instructions below:
Step Action
1 Click on the button Select the step in the box located in bottom of the screen on the left
2
In the dialog box Select step and scenario:
  • select a solving scenario
  • select a computation step
Scenario states
States of a solving scenario can be as follows:
  • unprocessed (not processed yet)
  • partly processed (some steps are processed and some not)
  • fully processed (all the steps are processed)
Computation step states
States of a computation step are presented in the table below.
State Example Post-processing
unprocessed solving process non-achieved or achieved with user stop at the end of a step / adding a step to the scenario no
processed incorrectly solved
problem of convergence
user stop at the end of an iteration
yes
unsolved
error in modeling
no
correctly solved   yes
