Volume: about
Volumes
Volumes can be built by Flux PEEC:
with the aid of automatic construction algorithm
(automatic identification and creation)
- by propagation from existing volumes with the aid of a transformation
- by extrusion from existing faces with the aid of a transformation
Volumes built by Flux PEEC
The volumes built by Flux PEEC are the ones defined by planar faces. The types of volumes are presented in the table below:
Volume of following type | is built … |
automatic |
