getVolActor()
Return volume actor specified by its information.
Usage
volActor = vis.getVolActor( volInfo )
volInfo (integer) or (string)
Name or ID of a volume.
Return Value
volActor (object)
Volume actor corresponding to the volInfo.
volInfo should be valid.
This routine returns the volume actor specified by its name or ID which is given by volInfo. For example,
imp = vis.getVolActor( "impeller" )
