AcuLmf
Updates a license file.
acuLmf [options]
AcuSolve License Manager Program
In the following, the full name of each option is followed by its abbreviated name and its type. For a general description of option specifications, see Command Line Options and Configuration Files. See below for more individual option details:
- help or h (boolean)
- If set, the program prints a usage message and exits. The usage message includes all available options, their current values, and the place where each option is set.
- lm_license_file or lmfile (string)
- Full address of the license file. When this option is set to _auto, the value is internally changed to $ACUSIM_HOME/$ACUSIM_MACHINE/license.dat.
- input_file or infile (string)
- Input license file name. Extra lines and characters will be removed and the license information properly formatted.
- verbose or v (integer)
- Set the verbose level for printing information to the screen. Each higher verbose level prints more information. If verbose is set to 0 (or less), only warning and error messages are printed. If verbose is set to 1, basic processing information is printed in addition to warning and error messages. This level is recommended. verbose levels greater than 1 provide information useful only for debugging.
Examples
acuLmf -lmfile /Acusim/license.dat -infile /tmp/license.txt
acuLmf -infile /tmp/license.txt
acuLmf -infile _stdin < /tmp/license.txt
acuLmf < /tmp/license.txt
acuLmf
<user types or pastes in content of /tmp/license .txt>
