Utility Scripts
AcuSolve contains a number of command line utility scripts that can be used for pre-processing the model, post-processing the model, running the model, and for monitoring the solution as it progresses.
These scripts are shipped with the distribution and are located in the /script and /bin directories of the installation. Each script has a full help listing that can be accessed using the "-h" command line option. The list below provides a brief summary of each script. Additional details can be found in the MANIFEST .txt file that is shipped with the distribution.
acuDdc
External domain decomposition for AcuPrep.
acuDmg
AcuSolve directory management tool for deleting output files.
acuDplace
Script to determine optimum process placement for Altix.
acuEnSight6To5
Convert an Ensight6 file to Ensight5.
acuEnv
Script to set AcuSolve's environment variables.
acuExtrudeSurf
Extrude a surface mesh to form a volume.
acuFmtArray
ASCII/binary conversion of AcuSolve files.
acuFv2H3D
Convert a FieldView file to H3D.
acuFwh
Ffowcs-Williams-Hawking solver.
acuGetData
Get AcuSolve results data directly from the AcuSolve output database.
acuGetCpCf
Script to calculate pressure and friction coefficients.
acuGetNodeSubset
Script to extract a subset of nodal output to disk.
acuHeatBalance
Compute the energy balance from an AcuSolve solution database.
acuImport
Import CFD files to AcuSolve.
acuInterp
Interpolate AcuSolve solution to requested points.
acuLiftDrag
Script to calculate lift and drag coefficients for one or more surfaces.
acuLmco
License manager co-processor for Linux based platforms.
acuLmd
License manager daemon.
acuLmf
Install license in the license file.
acuLmg
License manager user tool.
acuLmi
License machine info.
acuMakeDll
User-defined function make utility for AcuSolve (Windows).
acuMakeLib
User-defined function make utility for AcuSolve (Linux).
acuMesh2Tet
Convert a mesh to all tet mesh.
acuModSlv
Script to modify solver commands for utilization with the fast restart option.
acuOdb
Translate AcuSolve results to Abaqus ODB.
acuOptiStruct
Script to generate an OptiStruct input deck for thermal stress analysis.
acuOut
A GUI-based output translator to convert AcuSolve results into different formats.
acuPbc
Extract the build periodic BC set.
acuPerl
Windows .bat file to run AcuSolve perl scripts.
acuPev
Project EigenVectors for FLEXIBLE_BODY.
acuPlotData
Plot data from text files using matplotlib.
acuPmb
Pallas MPI Benchmark V2.2.
acuPorous
Simple curve-fit to get Darcy/Forch. coefficients to create porosity model inputs.
acuPrep
Prep the user data to be run by AcuSolve.
acuProbe
Plot time series solution and convergence.
acuProj
Project the solution to a new mesh.
acuPython
Run a Python script using AcuSolve's Python environment.
acuReport
Generate a report from a solution database.
acuRun
Script to run AcuPrep, AcuView and AcuSolve.
acuRunFwh
Script to acuFwh.
acuRunTrace
Compute steady particle traces.
acuScs
Extract simply connected sub meshes.
acuSetNodeValue
Set nodal values based on a user equation.
acuSflux
Compute flux table for SOLAR_RADIATION.
acuSif
Split internal faces of a mesh.
acuSig
Signal to AcuSolve (to output, stop, and so on.)
acusim
Set ACUSIM environment.
acuSolve
Main solver.
acuSolve-cuda-sp
NVIDIA GPU version of AcuSolve.
acuSolve-rocm-sp
AMD GPU version of AcuSolve.
acuSpec
Compute power spectrum using FFT or MEM.
acuSub
Submit an AcuSolve job to PBS/LSF/CCS queue.
acuSurf
Extract external surfaces of a mesh for imposing boundary conditions.
acuTherm
Translates the AcuSolve solution to an input file for TAITherm.
acuTrace
New particle tracer (run through acuRunTrace).
acuTrace2Ensight
Convert AcuTrace results to EnSight.
acuTrans
Translate AcuSolve results to other formats.
acuTransTrace
Translate AcuTrace results to other formats.
acuView
Calculate radiation view factors.
