Nastran Interface 2022.2 Release Notes
Altair HyperMesh
New Features
- Extension of Section Property tools
Figure 1. - Support for single beamsection creation
 - Support for single beamsection creation of config Shell | Solid | Elastic sections from model data along with existing beam property update.
Enhancements
- Previous Section Property tool is extended to create single beamsections (without target beam) . The existing capability to update beam properties of several beams from an intersection with the model is contained inside the option Update beams.
 - Solid beamsection config is now supported.
 - New option to generate a sketch entity along with beamsection.
Resolved Issues
- 3D detailed visualization of Elastic section generated by Section Property is lost when opening an *.hm binary file if no sketch is assigned.
 - Inconsistent creation of NLOUT card
 - Quick find with incorrect tool tip for CPYRAM
