OptiStruct Interface 2022.2 Release Notes
Altair HyperMesh
New Features
- Extension of Section Property tools
Figure 1. - Support for single beamsection creation
 - Support for single beamsection creation of config Shell | Solid | Elastic sections from model data along with existing beam property update. VABS is limited to beam property update as it requires you to create a PBEAML for OptiStruct.
Enhancements
- Previous Section Property tool is extended to create single beamsections (without target beam) . The existing capability to update beam properties of several beams from an intersection with the model is contained inside the option Update beams.
 - Solid beamsection config is now supported.
 - New option to generate a sketch entity along with beamsection.
- Keyword Enhancements
- Rayleigh damping continuation line in MAT1,MAt2,MAT8,MAT9 and MAT9OR
 - New PARAM option FCACSV to output.cmode.csv file
 - NLMON enhanced to include MONITOR option
 - Default value update for A/R field in MATFAT EN option
 - DTABLE support in Entity Editor
 - Optimization control parameters are supported in Entity Editor
 - Discrete design variable DDVAL supported in Entity Editor
 - Panel Removal Enhancements
- SPCP removed from force panel and accessible from Solver Browser
 - CURRENT and CDENST4 removed from analysis panel and accessible from Solver Browser
 - Some of the optimization cards enhanced to remove panel dependency
Resolved Issues
- 3D detailed visualization of Elastic section generated by Section Property is lost when opening an *.hm binary file if no sketch is assigned.
 - Unable to card edit CWELD Element.
 - Subcase selection in DCONSTR was missing for input file with PFMOD.
 - CGAP node projection
 - Incorrect import of Contact clearance value with exponential format
