EXX## Keyword §1 and number #1, option §2 and id #2, §1 clashes with #2Error Code
When an error occurs, nanoFluidX will issue a corresponding code for that error. An error code starts with the letter E followed by a two-letter category identifier. For example, IO for input/output. The last element of the error code is a number representing the order within the category. For example, EIO 338.
Error Message
- §: This symbol represents a string such as a phase name or file path. These symbols are followed by a number according to their order in the message. A recurring § symbol will keep the same number.
- #: This symbol represents a number such as a phase ID or motion ID. These symbols are followed by a number according to their order in the message. A recurring # symbol will keep the same number.
Error Description
This is an interpretation of the solver message. It may involve further explanation on why a certain situation occurs, the reason why the message has been issued, or the steps to take to alleviate the problem. It is meant as a first point of reference when a question on a certain message arises.
ECM - CELLMESH
ECM1
Cell number exceeds value range representable by ID type.ECM2
Resource limit in #1, #2 (#3,#4,#5) at (#6,#7,#8) in #9- particles clumping due to compression between moving walls
- too large of a timestep size
- too large of a single phase surface tension coefficient
- incorrect motion definitions
- unusual motion combinations
- kernel dx in cfg doesn't match the actual dx in the discretized geometry
- discretized geometric irregularities
- hanging or overlapping particles
ECM3
Resource limit in #1, #2 (#3,#4,#5) at (#6,#7,#8) in #9EDM - DOMAIN
EDM1
There are no motions, inlet regions or imposed regions to deduce a reference velocity. Please provide an explicit ref_vel in domain parameters section of the configuration file.EDM2
The reference velocity "ref_vel" must be explicitly defined when a POSITION_FILE motion is present.EDM3
The reference velocity "ref_vel" must be explicitly defined when a PASSIVE_RIGID_BODY motion is present.EDM4
Reference length "ref_length" must be explicitly specified when acceleration file ("bodyforce" file) is present.EDM5
The simulation cannot start without a valid "domain" section.EDM6
The simulations should be either two- or three-dimensional.EDM7
Input for"min_domain" and "max_domain" is inconsistent.EDM8
No Inputfile provided.EDR - DYEREGIONS
EDR1
Dye color for dyeRegion #1 should be a positive integer.EFS - FRAMESUITE
EFS1
The "frame_obj_phase" is assigned to phase #1 which is larger than the total number of defined phases.EFS2
The "frame_obj_phase" is not assigned to a phase.EFS3
The "frame_obj_phase" of a SLIDING frame is assigned to phase S1 which is not a MOVINGWALL.EFS4
The "frame_obj_phase" of a TEMPORAL frame is assigned to phase S1 which is not a WALL.EFS5
The "frame_obj_phase" keyword of a SLIDING frame has not been defined.EFS6
The "frame_road_phase" is assigned to phase #1 which is larger than the total number of defined phases.EFS7
The "frame_road_phase" is not assigned to a phase.EFS8
The "frame_road_phase" of a SLIDING frame is assigned to phase S1 which is not a MOVINGWALL.EFS9
The "frame_road_phase" of a TEMPORAL frame is assigned to phase S1 which is not a WALL.EFS10
The "frame_road_phase" keyword has not been defined.EFS11
The "frame_fluid_phase" is assigned to phase #1 which is larger than the total number of defined phases.EFS12
The "frame_fluid_phase" is not assigned to a phase.EFS13
The "frame_fluid_phase" is assigned to phase S1 which is not a FLUID.EFS14
The "frame_fluid_phase" keyword has not been defined.EFS15
Invalid value for parameter "frame_lock_mode": #1.EFS16
Invalid value for parameter "frame_min_bc_overlay": "#1 #2 #3".EFS17
Invalid value for parameter "frame_max_bc_overlay": "#1 #2 #3".EFS18
Freeze layers have non-positive extension length.EFS19
Sponge layers have non-positive extension length.EFS20
Invalid value for parameter "frame_freezesponge_min_bc_clip": "#1 #2".EFS21
Invalid value for parameter "frame_freezesponge_max_bc_clip": "#1 #2".EFS22
Bounding box not defined in "domain" section of the cfg.EFS23
Domain size not defined in "domain" section of the cfg.EFS24
Less than two points in the road path.EFS25
The road path must be strictly increasing in x coordinates.EFS26
Less than two points in the road profile.EFS27
The road profile must be strictly increasing in y coordinates.EIM - IMPOSEREGIONS
EIM1
Magnitude of direction vector A for PARALLELEPIPEDVEL impose region #1 is too small.EIM2
Length in A direction for PARALLELEPIPEDVEL impose region #1 must be non-negative.EIM3
Magnitude of direction vector B for PARALLELEPIPEDVEL impose region #1 is too small.EIM4
Length in B direction for PARALLELEPIPEDVEL impose region #1 must be non-negative.EIM5
Magnitude of direction vector C for PARALLELEPIPEDVEL impose region #1 is too small.EIM6
Length in C direction for PARALLELEPIPEDVEL impose region #1 must be non-negative.EIM7
Vectors A, B, and C defined for PARALLELEPIPEDVEL impose region #1 generate no volume, and will not have effect.EIM8
The phase number requested for impose region #1 to move with is either non-positive or larger than the total number of phases.EIM9
The phase requested for impose region #1 to move with is not a moving wall.EIM10
Direction vector magnitude for a PARALLELEPIPEDVEL impose region is too small.EIM11
Axis vector magnitude for CYLINDERVEL impose region #1 is too small.EIM12
The height of CYLINDERVEL impose region #1 must be non-negative.EIM13
The radius of CYLINDERVEL impose region #1 is negative.EIM14
The phase number requested for impose region #1 to move with is either non-positive or larger than the total number of phases.EIM15
The phase requested for impose region #1 to move with is not a moving wall.EIM16
Velocity direction vector for CYLINDERDVEL impose region #1 is too small.EIM17
Magnitude of direction vector A for PARALLELEPIPEDACC impose region #1 is too small.EIM18
Length in A direction for PARALLELEPIPEDACC impose region #1 must be non-negative.EIM19
Magnitude of direction vector B for PARALLELEPIPEDACC impose region #1 is too small.EIM20
Length in B direction for PARALLELEPIPEDACC impose region #1 must be non-negative.EIM21
Magnitude of direction vector C for PARALLELEPIPEDACC impose region #1 is too small.EIM22
Length in C direction for PARALLELEPIPEDACC impose region #1 must be non-negative.EIM23
Vectors A, B, and C defined for PARALLELEPIPEDACC impose region #1 generate no volume, and will not have effect.EIM24
The phase number requested for impose region #1 to move with is either non-positive or larger than the total number of phases.EIM25
The phase requested for impose region #1 to move with is not a moving wall.EIM26
Direction vector magnitude for a PARALLELEPIPEDACC impose region is too small.EIM27
Normal vector magnitude for CYLINDERACC impose region #1 is too small.EIM28
The height of CYLINDERACC impose region #1 must be non-negative.EIM29
The radius of CYLINDERACC impose region #1 must be non-negative.EIM30
The phase number requested for impose region #1 to move with is either non-positive or larger than the total number of phases.EIM31
The phase requested for impose region #1 to move with is not a moving wall.EIM32
Direction vector magnitude for a CYLINDERACC impose region is too small.EIM33
Magnitude of direction vector A for PARALLELEPIPEDTEMP impose region #1 is too small.EIM34
Length in A direction for PARALLELEPIPEDTEMP impose region #1 must be non-negative.EIM35
Magnitude of direction vector B for PARALLELEPIPEDTEMP impose region #1 is too small.EIM36
Length in B direction for PARALLELEPIPEDTEMP impose region #1 must be non-negative.EIM37
Magnitude of direction vector C for PARALLELEPIPEDTEMP impose region #1 is too small.EIM38
Length in C direction for PARALLELEPIPEDTEMP impose region #1 must be non-negative.EIM39
Vectors A, B, and C defined for PARALLELEPIPEDTEMP impose region #1 generate no volume, and will not have effect.EIM40
The phase number requested for impose region #1 to move with is either non-positive or larger than the total number of phases.EIM41
The phase requested for impose region #1 to move with is not a moving wall.EIM42
Normal vector magnitude for CYLINDERTEMP impose region #1 is too small.EIM43
The height of CYLINDERTEMP impose region #1 must be non-negative.EIM44
The radius of CYLINDERTEMP impose region #1 must be non-negative.EIM45
The phase number requested for impose region #1 to move with is either non-positive or larger than the total number of phases.EIM46
The phase requested for impose region #1 to move with is not a moving wall.EIM47
Magnitude of direction vector A for PARALLELEPIPEDPOROUS impose region #1 is too small.EIM48
Length in U direction for PARALLELEPIPEDPOROUS impose region #1 must be non-negative.EIM49
Magnitude of direction vector B for PARALLELEPIPEDPOROUS impose region #1 is too small.EIM50
Length in B direction for PARALLELEPIPEDPOROUS impose region #1 must be non-negative.EIM51
Magnitude of direction vector C for PARALLELEPIPEDPOROUS impose region #1 is too small.EIM52
Length in C direction for PARALLELEPIPEDPOROUS impose region #1 must be non-negative.EIM53
Vectors A, B, and C defined for PARALLELEPIPEDPOROUS impose region #1 generate no volume, and will not have effect.EIM54
The phase number requested for impose region #1 to move with is either non-positive or larger than the total number of phases.EIM55
The phase requested for impose region #1 to move with is not a moving wall.EIM56
At least two of the "porous_principal_ax_x_i", "porous_principal_ax_y_i" and "porous_principal_ax_z_i" for phase #1 should be defined.EIM57
"porous_principal_ax_x_i" defined for region #1 has zero length.EIM58
"porous_principal_ax_y_i" defined for region #1 has zero length.EIM59
"porous_principal_ax_z_i" defined for region #1 has zero length.EIM60
"porous_principal_ax_x_i" and "porous_principal_ax_y_i" defined for phase #1 are not perpendicular.EIM61
"porous_principal_ax_x_i" and "porous_principal_ax_z_i" defined for region #1 are not perpendicular.EIM62
"porous_principal_ax_y_i" and "porous_principal_ax_z_i" defined for region #1 are not perpendicular.EIM63
"porous_principal_ax_x_i" and "porous_principal_ax_y_i" defined for region #1 are not perpendicular.EIM64
"porous_principal_ax_x_i" and "porous_principal_ax_z_i" defined for region #1 are not perpendicular.EIM65
"porous_principal_ax_y_i" and "porous_principal_ax_z_i" defined for region #1 are not perpendicular.EIM66
"porous_principal_ax_x_i", "porous_principal_ax_y_i" and "porous_principal_ax_z_i" defined for region #1 do not follow the right hand rule.EIM67
Normal vector magnitude for CYLINDERPOROUS impose region #1 is too small.EIM68
The height of CYLINDERPOROUS impose region #1 must be non-negative.EIM69
The radius of CYLINDERPOROUS impose region #1 must be non-negative.EIM70
The phase number requested for impose region #1 to move with is either non-positive or larger than the total number of phases.EIM71
The phase requested for impose region #1 to move with is not a moving wall.EIM72
At least two of the "porous_principal_ax_x_i", "porous_principal_ax_y_i" and "porous_principal_ax_z_i" for phase #1 should be defined.EIM73
"porous_principal_ax_x_i" defined for region #1 has zero length.EIM74
"porous_principal_ax_y_i" defined for region #1 has zero length.EIM75
"porous_principal_ax_z_i" defined for region #1 has zero length.EIM76
"porous_principal_ax_x_i" and "porous_principal_ax_y_i" defined for phase #1 are not perpendicular.EIM77
"porous_principal_ax_x_i" and "porous_principal_ax_z_i" defined for region #1 are not perpendicular.EIM78
"porous_principal_ax_y_i" and "porous_principal_ax_z_i" defined for region #1 are not perpendicular.EIM79
"porous_principal_ax_x_i" and "porous_principal_ax_y_i" defined for region #1 are not perpendicular.EIM80
"porous_principal_ax_x_i" and "porous_principal_ax_z_i" defined for region #1 are not perpendicular.EIM81
"porous_principal_ax_y_i" and "porous_principal_ax_z_i" defined for region #1 are not perpendicular.EIM82
"porous_principal_ax_x_i", "porous_principal_ax_y_i" and "porous_principal_ax_z_i" defined for region #1 do not follow the right hand rule.EIR - INLETREGIONS
EIR1
Inlet region #1 has no phases associated with it.EIR2
The phase number associated with inlet region #1 is either non-positive or larger than the total number of phases.EIR3
Inlet region #1 has to be associated with a fluid phase.EIR4
The phase number requested for inlet region #1 to move with is either non-positive or larger than the total number of phases.EIR5
The phase requested for inlet region #1 to move with is not a moving wall.EIR6
Inlet region #1 has non-positive extension length.EIR7
Inlet region #1 has no normal vector specified.EIR8
Inlet region #1 has a zero length normal vector.EIR9
Inlet region #1 has a normal vector with more than one non-zero element. The normal vector may only point in positive or negative direction of the global coordinate system.EIR10
Inlet region #1 has a zero length tangent vector.EIR11
Inlet region #1 has a tangent that is not perpendicular to its normal vector.EIR12
Inlet region #1 has a non-fluid phase number in its "inletregion_stf_phaselist".EIR13
Inlet region #1 does not include its own phase in the given "inletregion_stf_phaselist".EIR14
The stencil file S1 for inlet region #1 should have 3 or 4 columns.EIR15
The stencil file S1 for inlet region #1 has 4 columns. The option "inletregion_stf_phaselist" must be provided.EIR16
Please make sure to have #1 inlet regions using the stencil file S1, one for each phase.EIR17
Please make sure inlet regions using stencil file S1 have correct definition of their respective phases.EIR18
The points in the stencil file provided for inlet region #1 are not planar.EIR19
Inlet region #1 has negative radius.EIR20
The points in the stencil file provided for inlet region #1 are not planar.EIR21
Inlet region #1 has negative radius.EIR22
The stencil file of inlet region #1 has less than two points. Please specify the tangent vector manually using "inletregion_tan" field.EIR23
Failed to compute tangent vector for inlet region #1. Please specify the tangent vector manually using "inletregion_tan" field.EIR24
The computed tangent vector for inlet region #1 is not perpendicular to the specified normal vector. Please specify the tangent vector manually using "inletregion_tan" field.EIR25
The points in the stencil file provided for inlet region #1 are not planar.EIR26
Inlet region #1 has at least one negative length.EIR27
The stencil file of inlet region #1 has less than two points. Please specify the tangent vector manually using "inletregion_tan" field.EIR28
Failed to compute tangent vector for inlet region #1. Please specify the tangent vector manually using "inletregion_tan" field.EIR29
The computed tangent vector for inlet region #1 is not perpendicular to the specified normal vector. Please specify the tangent vector manually using "inletregion_tan" field.EIR30
The points in the stencil file provided for inlet region #1 are not planar.EIR31
Inlet region #1 has at least one negative length.EIR32
Inlet region #1 has a negative state. Please modify the normal to change the state direction.EIR33
Inlet region #1 has a state of type "vfl" or "mfl" with no valid stencil particles. Please specify a valid stencil file for "inletregion_stf_file" or use state type "vel".EIR34
Inlet region #1 crosses the domain boundaries in at least one direction.EIR35
Inlet region #1 crosses the domain boundaries in at least one direction.EIR36
Inlet region #1 was not able to walk to a close mesh particle. Please modify the "inletregion_cnt" or disable "inletregion_meshmatch".EIO - INPUTOUTPUT
EIO1
Cannot find Casefile S1EIO2
Found non-empty output data directory at S1 when "cleandir_opt" is set to BREAK.EIO3
Failed to create case directory.EIO4
Failed to create case directory.EIO5
Cannot find Casefile S1EIO6
Failed to empty OUTPUT directory.EIO7
Failed to empty PREVIEW directory.EIO8
Failed to empty RECON directory.EIO9
Failed to empty LOG directory.EIO10
Failed to empty PHASEINFO directory.EIO11
Failed to empty PROBE directory.EIO12
Failed to empty MOTION directory.EIO13
Failed to empty STL directory.EIO14
Failed to empty STL directory.EIO15
Failed to empty PVSTATE directory.EIO16
Failed to empty EXTRACT directory.EIO17
Failed to create OUTPUT directory.EIO18
Failed to create PREVIEW directory.EIO19
Failed to create RECON directory.EIO20
Failed to create LOG directory.EIO21
Failed to create PHASEINFO directory.EIO22
Failed to create PROBE directory.EIO23
Failed to create MOTION directory.EIO24
Failed to create UTM directory.EIO25
Failed to create STL directory.EIO26
Failed to create PVSTATE directory.EIO27
Failed to create EXTRACT directory.EIO28
Failed to create output rank directories.EIO29
Failed to create preview rank directories.EIO30
Failed to create restart/continue rank directories.EIO31
Cannot find or failed to open input archive S1.EIO32
Failed to open S1 of input archive S2.EIO33
Encountered an error while reading S1 of input archive S2.EIO34
Cannot find inputfile S1EIO35
Cannot find Inputfile S1EIO36
Unexpected number of columns in the inputfile.EIO37
Unexpected number of columns in the inputfile.EIO38
Unexpected number of columns in the inputfile.EIO39
Problem opening the bodyforce fileEIO40
Empty line in bodyforce file S1EIO41
Problem reading the bodyforce fileEIO42
Problem opening the road path file S1.EIO43
Empty line in the road path file S1.EIO44
Problem reading the road path file S1.EIO45
Problem opening the road profile file S1.EIO46
Empty line in the road profile file S1.EIO47
Problem reading the road profile file S1.EIO48
Unable to access case directory S1EIO49
Root path S1 is not a directory.EIO50
Cannot write to case directory S1EIO51
Cannot read from case directory S1EIO52
Could not determine file system topology.EIO53
File system topology is ambiguous. Only one file system for all nodes or one file system per node is supported.EIO54
File system topology is ambiguous. Only one file system for all nodes or one file system per node is supported.EIO55
Cannot find/open the time-velocity series file S1 for a PARALLELEPIPEDVEL impose region #1.EIO56
Empty line in time-velocity series file S1 for a PARALLELEPIPEDVEL impose region #1.EIO57
Encountered a problem while reading time-velocity series file S1 for PARALLELEPIPEDVEL impose region #1.EIO58
Cannot find/open the time-velocity series file S1 for CYLINDERVEL impose region #1.EIO59
Empty line in time-velocity series file S1 for CYLINDERVEL impose region #1.EIO60
Encountered a problem while reading time-velocity series file S1 for CYLINDERVEL impose region #1.EIO61
Cannot find/open the time-acceleration series file S1 for a PARALLELEPIPEDACC impose region #1.EIO62
Empty line in time-acceleration series file S1 for a PARALLELEPIPEDACC impose region #1.EIO63
Encountered a problem while reading time-acceleration series file S1 for PARALLELEPIPEDACC impose region #1.EIO64
Cannot find/open the time-acceleration series file S1 for a CYLINDERACC impose region #1.EIO65
Empty line in time-acceleration series file S1 for a CYLINDERACC impose region #1.EIO66
Encountered a problem while reading time-acceleration series file S1 for CYLINDERACC impose region #1.EIO67
Cannot find/open the time-temperature series file S1 for a PARALLELEPIPEDTEMP impose region #1.EIO68
Empty line in time-temperature series file S1 for a PARALLELEPIPEDTEMP impose region #1.EIO69
Encountered a problem while reading time-temperature series file S1 for PARALLELEPIPEDTEMP impose region #1.EIO70
Cannot find/open the time-temperature series file S1 for a CYLINDERTEMP impose region #1.EIO71
Empty line in time-temperature series file S1 for a CYLINDERTEMP impose region #1.EIO72
Encountered a problem while reading time-temperature series file S1 for CYLINDERTEMP impose region #1.EIO73
Cannot find/open the stencil file S1 for inlet region #1.EIO74
Empty line in stencil file S1 for inlet region #1.EIO75
Encountered a problem while reading stencil file S1 for inlet region #1.EIO76
Not all phases mentioned in "inletregion_stf_phaselist" for inlet region #1 were found in file S1.EIO77
Encountered a negative state magnitude while reading time-state series file S1 for inlet region #1.EIO78
Cannot find/open the time-state series file S1 for inlet region #1.EIO79
Empty line in time-state series file S1 for inlet region #1.EIO80
Encountered a problem while reading time-state series file S1 for inlet region #1.EIO81
Cannot find prescribed motion file S1EIO82
Encountered an empty line while reading the header of prescribed motion file S1EIO83
Encountered a problem while reading the header of prescribed motion file S1EIO84
Encountered an empty line while reading prescribed motion file S1EIO85
Encountered a problem while reading the prescribed motion file S1EIO86
Cannot find/open the road path file S1 for motion #1.EIO87
Empty line in road path file S1 for motion #1.EIO88
Encountered a problem while reading road path file S1 for motion #1.EIO89
Cannot find/open the preset time dependent linear velocity file (prbcon_linvel_f_c) S1 for passive rigid body motion #1.EIO90
Empty line in preset time dependent linear velocity file (prbcon_linvel_f_c) S1 for passive rigid body motion #1.EIO91
Encountered a problem while reading time dependent linear velocity file (prbcon_linvel_f_c) S1 for passive rigid body motion #1.EIO92
Cannot find/open the preset time dependent angular velocity file (prbcon_angvel_f_c) S1 for passive rigid body motion #1.EIO93
Empty line in preset time dependent angular velocity file (prbcon_angvel_f_c) S1 for passive rigid body motion #1.EIO94
Encountered a problem while reading time dependent angular velocity file (prbcon_angvel_f_c) S1 for passive rigid body motion #1.EIO95
Encountered a negative state magnitude while reading time-state series file S1 for outlet region #1.EIO96
Cannot find/open the time-state series file S1 for outlet region #1.EIO97
Empty line in time-state series file S1 for outlet region #1.EIO98
Encountered a problem while reading time-state series file S1 for outlet region #1.EIO99
The probe points file S1 specified for probe S2 contains less than two points.EIO100
Cannot find/open the probe points file S1 specified for probe S2.EIO101
Empty line in the probe points file S1 specified for probe S2.EIO102
Encountered a problem while reading the probe points file S1 specified for probe S2.EIO103
Bounding Box needs to be read from the restart/continue (recon) file.EIO104
Encountered a problem while reading the inputfile (for BB).EIO105
Domain Dimensions need to be read from the restart/continue (recon) file.EIO106
Could not determine the latest restart/continue (recon) file. Please use \"restart_from_step\" keyword to specify the timestep explicitly.EIO107
Unable to find restart/continue (recon) file S1EIO108
Incompatible restart/continue (recon) file version (supplied/required): #1/#2EIO109
Encountered a problem while reading restart/continue (recon) file S1EIO110
Unable to find restart/continue (recon) file S1EIO111
Problem opening the particle output times file S1EIO112
Empty line in particle output times file S1EIO113
Problem reading the particle output times file S1EIO114
Problem opening the restart output times file S1EIO115
Empty line in restart output times file S1EIO116
Problem reading the restart output times file S1EIO117
Cannot find/open the stl file S1 for extractor S2.EIO118
Encountered a problem while reading the input geometry file.EIO119
Encountered a problem with the (restart/continue) recon file (nonexistent or unreadable) S1EIO120
Encountered a problem while reading restart/continue (recon) file S1EIO121
Failed to create EXTRACT sub directory for vtp output of extractor S1.EIO122
Failed to create EXTRACT sub directory for synchronized output S1.EIO123
Failed to create EXTRACT sub directory for txt output of extractor S1.EIO124
Failed to create EXTRACT sub directory for info output of extractor S1.EIO125
Failed to create EXTRACT sub directory for synchronized info output of extractor S1.EIO126
Encountered a problem while opening stl file S1 for extractor S2.EIO127
Encountered a problem while reading stl file S1 for extractor S2.EKR - KERNEL
EKR1
The simulation cannot start without a valid "kernel" section.EKR2
Either `dx' or `cutoff' need to be specified in the configuration file.EMT - MOTIONS
EMT1
Invalid "max_dist" is specified for motion #1 applied to phase #2.EMT2
Invalid "max_dist" is specified for motion #1 applied to phase #2.EMT3
Invalid "max_dist" is specified for motion #1 applied to phase #2.EMT4
Motion #1 is assigned to phases #2 and #3, where at least one is larger than the total number of defined phases.EMT5
Motion #1 is assigned to phases #2 and #3, where at least one phase is not a MOVINGWALL.EMT6
CONROD motion #1 has no phase_piston and/or phase_conrod assigned.EMT7
Motion #1 is assigned to phase #2 which is larger than the total number of defined phases.EMT8
At least one motion is defined but not assigned to a phase.EMT9
Motion #1 is assigned to phase S1 which is not a WALL or a MOVINGWALL.EMT10
Motion #1 is assigned to phase S1 which is not a MOVINGWALL.EMT11
"rot_freq" of motion #1 not defined or with zero magnitude.EMT12
"rot_axis" of motion #1 not defined or with zero magnitude.EMT13
"conrod_axis" of motion #1 not defined or with zero magnitude.EMT14
"crankshaft_normal" of motion #1 not defined or with zero magnitude.EMT15
No prescribed motion file specified in the configuration file of motion #1EMT16
Body motion #1 is assigned to phase #2 which is larger than the total number of defined phases or less than 1.EMT17
Front wheel Motion #1 is assigned to phase #2 which is larger than the total number of defined phases or less than 1.EMT18
Rear wheel Motion #1 is assigned to phase #2 which is larger than the total number of defined phases or less than 1.EMT19
Motion #1 has phase #2 assigned to both body and front wheels.EMT20
Motion #1 has phase #2 assigned to both body and rear wheels.EMT21
Motion #1 has phase #2 assigned to both front and rear wheels.EMT22
Motion #1 supports "reardrive" and "frontdrive" options only.EMT23
Motion #1 is missing forward axis point definition.EMT24
Motion #1 is missing rear axis point definition.EMT25
Coordinate x of the front wheel is less than or equal to that of the rear wheel in motion #1.EMT26
Motion #1 is missing wheel radius definition.EMT27
Wheel radius of Motion #1 is not positive.EMT28
Arc segment length coefficient of motion #1 is missing wheel radius definition.EMT29
Road path file of motion #1 has less than two points.EMT30
The x coordinate values (first column) of the road path file of motion #1 must be strictly increasing.EMT31
A piece of the road path file of motion #1 has zero length.EMT32
A piece of the road path file of motion #1 has zero length.EMT33
At least two consecutive pieces of the road path file of motion #1 have the same slope.EMT34
A piece of the elevated road of motion #1 has zero length.EMT35
The initial position of wheel axes of motion #1 must lie within the first road piece.EMT36
At least two of the mom_principal_ax_x_i, mom_principal_ax_y_i and mom_principal_ax_z_i for phase #1 should be defined.EMT37
mom_principal_ax_x_i defined for phase #1 has zero length.EMT38
mom_principal_ax_y_i defined for phase #1 has zero length.EMT39
mom_principal_ax_z_i defined for phase #1 has zero length.EMT40
mom_principal_ax_x_i and mom_principal_ax_y_i defined for phase #1 are not perpendicular.EMT41
mom_principal_ax_x_i and mom_principal_ax_z_i defined for phase #1 are not perpendicular.EMT42
mom_principal_ax_y_i and mom_principal_ax_z_i defined for phase #1 are not perpendicular.EMT43
mom_principal_ax_x_i and mom_principal_ax_y_i defined for phase #1 are not perpendicular.EMT44
mom_principal_ax_x_i and mom_principal_ax_z_i defined for phase #1 are not perpendicular.EMT45
mom_principal_ax_y_i and mom_principal_ax_z_i defined for phase #1 are not perpendicular.EMT46
mom_principal_ax_x_i, mom_principal_ax_y_i and mom_principal_ax_z_i defined for phase #1 do not follow the right hand rule.EMT47
At least two of the prbcon_ax_x_i, prbcon_ax_y_i and prbcon_ax_z_i for phase #1 should be defined.EMT48
prbcon_ax_x_i defined for phase #1 has zero length.EMT49
prbcon_ax_y_i defined for phase #1 has zero length.EMT50
prbcon_ax_z_i defined for phase #1 has zero length.EMT51
prbcon_ax_x_i and prbcon_ax_y_i defined for phase #1 are not perpendicular.EMT52
prbcon_ax_x_i and prbcon_ax_z_i defined for phase #1 are not perpendicular.EMT53
prbcon_ax_y_i and prbcon_ax_z_i defined for phase #1 are not perpendicular.EMT54
prbcon_ax_x_i and prbcon_ax_y_i defined for phase #1 are not perpendicular.EMT55
prbcon_ax_x_i and prbcon_ax_z_i defined for phase #1 are not perpendicular.EMT56
prbcon_ax_y_i and prbcon_ax_z_i defined for phase #1 are not perpendicular.EMT57
prbcon_ax_x_i, prbcon_ax_y_i and prbcon_ax_z_i defined for phase #1 do not follow the right hand rule.EMT58
At most one element of prbcon_ax_hinge_c defined for phase #1 may be set to 1.EMT59
"year_rotVector" must have a nonzero magnitude.EMT60
"day_rotVector' must have a nonzero magnitude.EMT61
Invalid frequency unit ("freq_unit") for a non-"PASSIVE_RIGID_BODY" motion: S1. Options are "Hz", "RPM", "Rad/s" and "Rad/min" (default: "Hz")EMT62
Invalid frequency unit ("freq_unit") for a "PASSIVE_RIGID_BODY" motion: S1. Options are "Hz", "RPM", "Rad/s" and "Rad/min" (default: "Rad/s")EOR - OUTLETREGIONS
EOR1
A phase number associated with outlet region #1 is either non-positive or larger than the total number of phases.EOR2
An invalid extension type is requested for outlet region #1. Please use setacc, setvel or noext.EOR3
Outlet region #1 has non-positive extension length.EOR4
Outlet region #1 has a zero length normal vector.EOR5
Outlet region #1 has a normal vector with more than one non-zero element. The normal vector may only point in positive or negative direction of the global coordinate system.EOR6
Outlet region #1 has no normal vector specified.EOR7
Outlet region #1 has a zero length normal vector.EOR8
Outlet region #1 has a normal vector with more than one non-zero element. The normal vector may only point in positive or negative direction of the global coordinate system.EOR9
Outlet region #1 has no normal vector specified.EOR10
Outlet region #1 has a zero length normal vector.EOR11
Outlet region #1 has a normal vector with more than one non-zero element. The normal vector may only point in positive or negative direction of the global coordinate system.EOR12
Sphere outlet region #1 has no radius specified.EOR13
Sphere outlet region #1 has non-positive radius.EOR14
Cuboid outlet region #1 has no length specified.EOR15
Cuboid outlet region #1 has at least one non-positive length value.EOR16
Cylinder outlet region #1 has no radius specified.EOR17
Cylinder outlet region #1 has non-positive radius.EOR18
Cylinder outlet region #1 has no height specified.EOR19
Cylinder outlet region #1 has non-positive height.EOR20
Outlet region #1 has negative state. Please modify the normal to change state direction.EPH - PHASES
EPH1
Number of phases bigger than maximum allowed (#1).EPH2
The simulation cannot start without a valid "phases" section.EPH3
The contact angle requested for phase #1 has an invalid value: #2.";EPH4
Phase #1, requested for calculating fluid contact time of solid phase #2, is larger than the total number of phases, #3.EPH5
The fluid contact time is requested for phase #1 which is not a WALL or MOVINGWALL.EPH6
The non-fluid phase #1 is assigned for calculating fluid contact time of solid phase #2.EPH7
Subphase option is not supported with energy transport in non-isothermal solids.EPR - PROBES
EPR1
Probe number #1 of type S1 requires at least one fluid phase definition. There is no fluid phase present in the cfg.EPR2
Unknown probe type S1 for probe number #1.EPR3
No normal vector has been specified for probe S1.EPR4
The normal vector specified for probe S1 has zero magnitude.EPR5
No normal vector has been specified for probe S1.EPR6
The normal vector specified for probe S1 has zero magnitude.EPR7
The parallel vector specified for probe S1 has zero magnitude.EPR8
Parallel and normal vectors specified for probe S1 are not sufficiently perpendicular.EPR9
Probe S1 is attached to phase number #1, which is greater than the total number of phases at #2.EPR10
Probe S1 is attached to phase number #1, which is not a moving wall.EPR11
Probe S1 is attached to phase number #1, which is not a wall or a moving wall.EPR12
Probe S1 is not attached to a phase. Solid probes must attach to a wall or a moving wall to sample from.EPR13
Failed to compute parallel vector for probe S1. Please specify the parallel vector manually using "probe_tanvec" field.EPR14
The computed parallel vector for probe S1 is not perpendicular to the specified normal vector. Please specify the parallel vector manually using "probe_tanvec" field.ERT - RUNTIME
ERT1
Failed allocating 'h_localcell_owner' on HostERT2
Failed allocating 'd_localcell_owner' on GPUERT3
Failed allocating 'h_localcell_gID' on HostERT4
Failed allocating 'd_localcell_gID' on GPUERT5
Failed allocating 'h_remotecell_gID' on HostERT6
Failed allocating 'h_remotecell_lID' on HostERT7
Failed allocating 'h_remotecell_owner' on HostERT8
Failed allocating '_clist->at(i).pic' on GPUERT9
Failed allocating '_clist->at(i).beginIdx' on GPUERT10
Failed allocating '_clist->at(i).endIdx' on GPUERT11
Failed allocating '_clist->at(i).picYZLayer' on GPUERT12
Failed allocating 'd_localcell_weights' on GPUERT13
Failed allocating 'h_localcell_weights' on HostERT14
Failed reset 'd_localcell_weights' on GPUERT15
Failed downloading 'd_localcell_weights' from GPUERT16
Encountered a problem while loading inletregion stencils on GPUERT17
Encountered a problem while resizing prtl arrays on GPU in S1ERT18
Encountered a problem while resizing prtl buffers on GPU in S1ERT19
Encountered a problem while freeing prtl buffers on GPU in S1ERT20
Encountered a problem while resizing ghost arrays on GPU in S1ERT21
Encountered a problem while freeing ghost arrays on GPU in S1ERT22
Failed getting `pos' on GPUERT23
Failed getting `vel' on GPUERT24
Failed getting `prop.rho' on GPUERT25
Failed getting `prop.temp' on GPUERT26
Failed getting `prop.vol_frac' on GPUERT27
Failed getting `attr' on GPUERT28
Failed getting `gradc' on GPUERT29
Failed getting `curv_den' on GPUERT30
Failed getting `vcorr' on GPUERT31
Failed getting `wall normals' on GPUERT32
Failed getting `relpos' on GPUERT33
Failed getting `subphase' on GPUERT34
Failed getting `dyecolor' on GPUERT35
Failed getting `fluidContact' on GPUERT36
Failed getting `pos' from GPUERT37
Failed getting `vel' from GPUERT38
Failed getting `acc' from GPUERT39
Failed getting `gradc' from GPUERT40
Failed getting `gradc2' from GPUERT41
Failed getting `vcorr' from GPUERT42
Failed getting `prop' from GPUERT43
Failed getting `prop.temp' from GPUERT44
Failed getting `prop.visctemp' from GPUERT45
Failed getting `prop.vol_frac' from GPUERT46
Failed getting `attr' from GPUERT47
Failed getting `wall' from GPUERT48
Failed getting `moving wall' from GPUERT49
Failed getting `subphase' from GPUERT50
Failed getting `dyecolor' from GPUERT51
Failed getting `fluidContact' from GPUESP - SIMPARAM
ESP1
Invalid input for keyword chain S1.S2: S3. Valid options are: S4ESP2
Missing input for keyword chain S1.S2. Valid options are: S3ESP3
Invalid input for keyword chain S1.S2(#1).S3: S4. Valid options are: S5ESP4
Missing input for keyword chain S1.S2(#1).S3. Valid options are: S4ESP5
Missing input for keyword chain S1.S2. The boundary conditions for each of the cordinate directions can be chosen from: S3ESP6
Missing input for keyword chain S1.S2(#1).S3. The boundary conditions for each of the cordinate directions can be chosen from: S4ESP7
DESIGN operation mode is only available for single fluid phase. For cases with more than one fluid, please use NORMAL or CONSERVATIVE operation modes.ESP8
More than two FLUID phases detected. The ADAMI surface tension model is not supported for more than two FLUID phases.ESP9
More than two FLUID phases detected. The TARTAKOVSKY2016_F1 surface tension model is not supported for more than two FLUID phases.ESP10
The simulation cannot start without a valid "simulationParameters" section.ESP11
Log output frequency "freq_log" has to be a positive integer value.ESP12
APD attenuation interval "APD_attenuation_interval" has equal start and end points.ESP13
It is not possible to activate "viscTempCoupling" without enabling "energy_transport".ESP14
"aeroViscMode" and "viscTempCoupling" may not be enabled simultaneously. Please choose only one.ESP15
The value of "restart_from_step" keyword is less than -1. The starting step of a restart/continue (recon) run must be a non-negative integer.ESP16
Output file write interval has to be defined either through "dt_output" or through "t_output_file" for "output_type" other than NOOUTPUT.ESP17
Time step size factor "dt_factor" must be a positive number.ESP18
The specified restart/continue (recon) time is greater than the end time of the simulation.ESP19
Too many GPU-devices requested. Currently limited to #1 GPUsESE - SURFEXTS
ESE1
The phase number requested for extractor S1 to move with is either non-positive or larger than the total number of phases.ESE2
The phase requested for extractor S1 to move with is not a moving wall.ESE3
Non-reset HTC is requested for extractor S1 without activating energy transport. Please activate "energy_transport" in "simulationParameters" section.ESE4
Both non-reset and reset HTC are requested for extractor S1. Please activate only one option.ESE5
Both non-reset and reset HTC are requested across at least two different extractors. Please activate only one option across all extractors.EVS - VISCTEMP
EVS1
It is not possible to enable temperature-viscosity coupling and have energy transport switch set to false.
