Inlet Regions
Defines inlet region parameters.
Inlet regions differ from the standard inlets in two ways. They can be defined anywhere inside the domain and they can be of arbitrary shape. They can also be prescribed through specified velocity of the flow, mass or volumetric flow (in units of m/s, kg/s or m3/s).
Inlet regions can be defined in rectangular, circular or custom shape. While the first two require just geometric description of the region as an input, the custom shaped region requires a “stencil” of particles in form of a separate .txt file. The .txt file for the custom shaped inlet region simply contains the coordinates (x, y, z) of the particles which are to be inserted into the domain. The stencil in that case behaves as a source of particles.
The only limitation to the inlet regions is that they must be planar, even in the custom shape or arbitrary orientation scenario.
For more information, refer to Inlet Regions in the Theory Manual.
inletregions
    inletregion
        inletregion_type            INREG_CIRCULAR
        inletregion_phase           1
        inletregion_motphs          7
        inletregion_nrm             "0.0 0.0 -1.0"
        inletregion_stttyp          vel
        inletregion_sttval          0.0
        inletregion_stf_file        "stencil-file.txt"
        inletregion_prefilled       true
        inletregion_indexsim        false
        inletregion_extend          true
        inletregion_extlen          0.1
        inletregion_extlenodx       4
        inletregion_cnt             "0.04 0.0105 0.03"
        inletregion_circle_rad      0.015
        inletregion_rectangle_len   "0.03 0.04 0.0"
        inletregion_time_start      0.0
        inletregion_time_end        0.05
        inletregion_time_rampup     0.01
        inletregion_time_rampdn     0.025
        inletregion_tss_file        time-state-series.txt
        inletregion_tss_offset      0.0
        inletregion_tss_latch       false
        inletregion_temp            0.0
        inletregion_extpre          false
        inletregion_extpst          false
}- inletregion_type
- Specifying the type of the outlet region.
- inletregion_phase
- Phase ID of the fluid spawned by the inlet region.
- inletregion_motphs
- This option is applicable only to *_ARBOR (arbitrary orientation) inlets.
- inletregion_nrm
- Direction vector of the inlet region (can only point in +/- X, Y, Z).
- inletregion_stttyp
- This command is optional.
- inletregion_sttval
- State magnitude of the inlet region.
- inletregion_stf_file
- Inlet region stencil file containing X, Y and Z coordinates of the seed inlet particles.
- inletregion_prefilled
- This command notifies the solver that at the time of the inlet region activation, there are fluid particles overlapping at the seeding coordinates of the inlet. If so, the command should be set to true.
- inletregion_indexsim
- Setting this value to true will result in the particles introduced by this inlet to follow the particle ID numbering in accordance with particle ID’s present in the domain at the time.
- inletregion_extend
- In order for the inlet region to function properly in a multiphase environment and reduce potential local instabilities, an impose region should be created in front of the inlet stencil particles (in the direction of the inlet normal). Setting this command to true automatically creates that impose region.
- inletregion_extlen
- Defines the absolute length of the impose region in front of the inlet region (in the direction of the inlet normal).
- inletregion_extlenodx
- Defines the relative length of the impose region in front of the inlet region (in the direction of the inlet normal) as a function of dx (particle pitch).
- inletregion_cnt
- X, Y and Z coordinates of the inlet region center.
- inletregion_circle_rad
- Radius of the circular inlet region.
- inletregion_rectangle_len
- Length of the sides of the rectangular inlet region in each direction.
- inletregion_time_start
- Time at which the inlet region becomes active.
- inletregion_time_end
- Time at which the inlet region becomes inactive.
- inletregion_time_rampup
- Time during which the inlet velocity value goes from zero to the specified peak value.
- inletregion_time_rampdn
- Time during which the inlet velocity value goes down from a specified peak value to zero.
- inletregion_tss_file
- For the inlet region there can be a Time State Series (TSS) file provided in ASCII format, specifying an arbitrary shape of the inlet flow magnitude as a function of time.
- inletregion_tss_offset
- Provided that the TSS file is used for the inlet region, this value offsets the beginning of the TSS file in time.
- inletregion_tss_latch
- Assuming that the TSS file for the inlet region is provided, this command extends the first and/or last specified value in the TSS file until start and/or end of the simulation, respectively.
- inletregion_temp
- Temperature of the inlet region.
- inletregion_extpre
- Notifies the solver about inlet region extension status before the inlet start time.
- inletregion_extpst
- Notifies the solver about inlet region extension status after the inlet start time.
