Free Surface Formulation
                           Standard SPH interpolation heavily depends on the basic premise that each particle         has the so called full support.
                              Full support implies that the owner particles can see         particles all around itself within the smoothing length of the
                              particle, which         mathematically implies that the sum of the kernel, also known as Shepard coefficient, is         equal
                              to one.
