Select a temperature factor and define its properties.
            The temperature factor icon is enabled when performing SN (uniaxial, multiaxial) and
                EN (uniaxial, multiaxial) fatigue analysis.
                Click the Material tool.
 The Assign Material dialog opens.
                Under the Temperature Factor field heading, click  . .
                In the dialog, select temperature factor from the drop-down menu.
                    - None: Ctemp = 1
- User Defined: Enter a Ctemp value
                        between 0.0 and 1.0
- FKM: Input a temperature in degrees Celsius and
                        select a material type. Ctemp is automatically
                        calculated.
                Click OK.
                The temperature factor is used to update the fatigue strength reduction
                            factor. Kf (mod) = Kf /
                    Ctemp
For more information, see
                Temperature Influence.
                Tip: Apply a temperature factor value to all the parts/sets by
                    right-clicking on
 and
                    selecting
Apply current value to all Parts/Sets.
