Load Maps
Use the Load Map tool to import/create multiple channels (load histories) which are then paired with subcases/loadsteps to create the fatigue events.
The information displayed in this dialog is dynamic. The available options change depending on the load type and the channel type.
| Type of Loading | Channel Type |
| Time Series | Time
                                    Data Constant Amplitude Block Loading Duty Cycle (*.dcy) |
| Transient Response | Transient Response |
| Modal Superposition | Eigen Value
                                    (*.pch) CMS (*.mrf) |
| Random (PSD Stresses) | PSD Stress |
| Random (Input PSD with FRF) | Input PSD: Phase and
                                    Magnitude Input PSD: Real and Imaginary |
| Sine Sweep | Constant Load Variable Scale |
